Two Outlets Not Working - Electrical - DIY Chatroom Home Improvement Forum
Old 08-13-2011, 07:32 PM   #1
Two outlets not working
Okay. We have one outlet in the living room that doesn't work. There's also another in one of the bedrooms that suddenly went caput. Everything else works. We thought it might be the outlets, so we changed them out. Nada. Everything else on the breakers in question are fine. There are only two wires in said outlets, but before, with the one that just stopped, both outlets worked.
Any ideas on 1) what's wrong and 2) how we can fix it. Hopefully without having to open the wall or call an electrician!
bratling is offline   Reply With Quote
Old 08-13-2011, 07:36 PM   #2
Licensed electrician
Rewards Points: 1,788
Look for a loose connection in a receptacle or switch closest to the ones that don't work.
Old 08-13-2011, 07:39 PM   #3
Learning by Doing
Leah Frances's Avatar
Look for upstream GFCIs.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 12:29 PM
Light switches not working but outlets are Jennybird Electrical 4 11-04-2010 10:15 AM
Replacing kitch outlets to GFCI jhubert Electrical 7 11-16-2009 07:23 PM
some outlets not working Clallen Electrical 5 06-08-2009 04:09 PM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 08:37 AM
