Old 09-23-2012, 10:12 PM   #1
Question
Two Main Breakers?
Our proposed new service entrance equipment is a meter socket with disconnect (200 Amp), all in one exterior mounted box. The Main Panel it feeds (in the basement) also has a Main Breaker (200 Amp). Any problem here or must the Main panel in the basement be lug? Thanks for your time.
steadyed is offline   Reply With Quote
Old 09-23-2012, 10:18 PM   #2
Licensed electrician
Two Main Breakers?
The inside breaker will just be redundant means to turn the power off.
Tags
main breaker, service entrance
building a main and sub panels for 2 remote buildings n175h Electrical 30 12-20-2011 03:09 PM
Main panel breakers, balanced loading? WoodmanFL Electrical 13 12-11-2011 08:40 PM
100AMP Main board off a 100AMP Main Fuse cmarcus3031 Electrical 17 07-03-2010 06:47 PM
Dual Main Breakers dcwestcott Electrical 3 02-23-2009 08:26 PM
Help! Circuit breakers in trouble Circuit breakers Electrical 9 12-22-2008 01:58 PM
