Two Lights W/one Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 12-03-2011, 01:58 PM   #1
Two lights w/one switch
I know this is easy but I can't seem to get it right. Basically I have two lights connected with 14-2. The power is coming in at the first light, then the wire goes to the second light, then goes to the switch. I was wandering if someone could show a simple sketch (kinda connecting the dots).
Strugglin is offline   Reply With Quote
Old 12-03-2011, 02:48 PM   #2
Electrician
SD515's Avatar
Rewards Points: 504
You cannot do it with 14/2 between the lights, as there is no way for the power to return from the switch to the first light. You need to have 14/3 between the lights (and 14/3 from the 2nd light to the switch if you’re on the 2011 code, to get the neutral to the switch box). Which code cycle is your area on?
Kyle
Old 12-03-2011, 03:14 PM   #3
joed's Avatar
Rewards Points: 13,720
You can't do it. You need 14/3 between the lights.
And if you are on a code that requires a neutral in the switch box then you need 14/3 to the switch box as well. This drawing was made before the neutral was required.
Old 12-03-2011, 04:01 PM   #4
This site is the best!!!
Thanks for the answers. I thought I had to add a wire between the two lights but didn't know for sure....or how to wire it up. The diagram is perfect.
Thanks again.
2 Wall Lights, 1 Switch twak21 Electrical 5 11-28-2011 06:59 PM
How to connect 2 lights to a double switch B4rg Electrical 7 05-09-2011 09:18 PM
Indoor switch for outdoor motion activated security lights youngdoc Electrical 5 12-02-2010 02:07 PM
Wiring a switch to rope lights DK75 Electrical 5 12-02-2010 07:49 AM
re: pendant lights on dimmer switch jho Electrical 11 03-26-2010 10:14 PM
