Two Light Switches In-line To Lights? - Electrical - Page 4 - DIY Chatroom Home Improvement Forum
Old 05-21-2013, 11:56 AM   #46
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 4,624
Originally Posted by rosem637 View Post
No trickery or play on words. I'll post answer tomorrow morn or maybe later this evening
Rose... before you post, can you tell us the distinct rules that I asked in above post....
Peter
MTN REMODEL LLC is offline   Reply With Quote
Old 05-21-2013, 12:16 PM   #47
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
Originally Posted by stickboy1375 View Post
There are no codes for switches to be required in rooms/halls/stairs that enter/exit....
Yep, same as the NEC, a wall controlled lighting outlet is required, but this mentions nothing about where the switch is located, the NEC is moot on this because it is purely a design issue.
Your words ....
And simply not true ....210.70(A)(3). At the very least
And if you really read 210.70(A)(1) both exceptions #1 and # 2 why are there exceptions ??
Exceptions to what .....hee heee hee the wall switch
I go back to 90(C) ........."or an instruction manual for untrained persons"
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 05-21-2013, 12:27 PM   #48
Rewards Points: 214
Originally Posted by MTN REMODEL LLC View Post
But what are the rules. What is definition of "regular switch" SPST or SPDT and no DPxDT (4way)... how many switches are you allowed at each location (floor)...
... and do the lights have to be able to be turned off at each location also?
A simple on-off switch: SPST like below. The two terminals are either connected together or disconnected from each other.
There is only one switch. But with this one switch the light at the top of the stairwell must be able to be controlled from all locations/floors
And yes the light must be able to be turned off from each location/floor.
here is the criteria again so you dont have to go back to page 3
In a stairwell for a four(4) story apartment building.
One(1) single pole switch controls a light bulb at the top of stairwell.
The switch can be controlled from each landing/floor.
How??
no remote switches, wireless switches or clappers.
rosem637 is offline   Reply With Quote
Old 05-21-2013, 01:20 PM   #49
bobgodd's Avatar
Rewards Points: 101
One of these guys hanging down the middle of the stairwell so it can be reached from every level?? Lol.
bobgodd is offline   Reply With Quote
Old 05-21-2013, 01:32 PM   #50
Rewards Points: 214
laugh if you will but you are on the right track
Old 05-21-2013, 01:34 PM   #51
bobgodd's Avatar
Rewards Points: 101
I only laugh because I'm so far from an expert. I'm the clueless homeowner who started this thread
Old 05-21-2013, 01:36 PM   #52
How??
Can ya disclose... Is it necessarily a toggle/rocker switch...
Old 05-21-2013, 01:37 PM   #53
Rewards Points: 214
I will disclose that it is not your typical wall light switch, toggle or rocker or decora.
Old 05-21-2013, 01:37 PM   #54
is the switch on a rope
Old 05-21-2013, 01:37 PM   #55
Licensed electrician
Rewards Points: 1,268
Originally Posted by Philly Master View Post
Your words ....
Article 210.70 only says that lighting outlets need to be installed in certain rooms of which a switched receptacle would satisfy. Other rooms(kitchens and bathrooms) the switched receptacle is not acceptable and the lighting outlet is required.
BTW, there is no requirement for a fixture to be installed at the lighting outlet.
The location of the switch is silent except for a few select locations like the attic, basements, and some stair landings. Someone could install all the other switches in one room and still satisfy the NEC.
I will paraphrase the Charlie B rule for you. Sometimes the NEC does not say what you think it says.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
MTN REMODEL LLC (05-21-2013), stickboy1375 (05-21-2013)
Old 05-21-2013, 01:38 PM   #56
Pull chain....
Old 05-21-2013, 01:39 PM   #57
Rewards Points: 214
I think you have it. Yes a rope(or long chain) is involved.
The Following User Says Thank You to rosem637 For This Useful Post:
Philly Master (05-21-2013)
Old 05-21-2013, 01:41 PM   #58
Oso954's Avatar
Rewards Points: 768
deleted, duplicate
Oso954 is online now   Reply With Quote
Old 05-21-2013, 01:44 PM   #59
Rewards Points: 214
once you found out the switch was not the typical light switch the ball started rolling
Old 05-21-2013, 01:47 PM   #60
Good
Sometimes.... much like code as as Jim points out.... our minds assume something that are not evidenced in fact.
OK.... So quote me the code section on how long that cord can be, it's tensile streangth, and kind of knot that connects it to the pull chain.
Peter
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
Why are switches placed furthest from light? cypherx Electrical 17 06-21-2012 06:48 PM
Replacing multi-use light switches jimclark Electrical 4 08-30-2011 03:05 PM
3-way switches, lights, and a photoelectric switch. Your thoughts? Fox Electrical 7 11-23-2010 11:08 AM
2 switches 2 lights line in through light 1 bldaz Electrical 9 12-24-2009 07:42 PM
3 switches 1 light. need 2 lights 2 switches. Im desprete s richards Electrical 6 07-19-2008 04:18 PM
