Two Light Switches In-line To Lights? - Electrical - Page 10 - DIY Chatroom Home Improvement Forum
Old 05-23-2013, 06:40 PM   #136
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by MTN REMODEL LLC View Post
Neat.... What kinda price (equipment) parameters are involved and THANKS
Peter
Main repeater is around $400
600 watt dimmers around $125 ea.
1000 watt dimmers around $175 ea.
6 button keypads around $250 ea.
table tops controllers around $400 ea.
This system is not for the average person, in case you couldn't tell.
In the pics I posted, the cost was probably about $2,750 worth of hardware, (plus mark up on material) not including what we already installed in the master bed and bath suite...
Also, you have to take a course from Lutron to get certified to install the hardware and receive the software to actually program the devices, which is good in one way, because it forces the end user to call us back to reprogram if changes are to be made.
The Following 2 Users Say Thank You to stickboy1375 For This Useful Post:
MTN REMODEL LLC (05-23-2013), Philly Master (05-23-2013)
Old 05-23-2013, 09:31 PM   #137
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
LOL ... good i have a question for you ... i need to take a picture first .. and i'll start new thread ...
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 05-24-2013, 09:35 PM   #138
E2 Electrician
go for it...
Old 05-24-2013, 10:26 PM   #139
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,850
Originally Posted by stickboy1375 View Post
go for it...
yeah.... Personally I learn alot. Thanjks
MTN REMODEL LLC is online now   Reply With Quote
Old 05-29-2013, 12:49 PM   #140
Code05's Avatar
Rewards Points: 1,104
Stickboy,
1. Ya got a 110.26(E)(1)(a) with those pipes under the panel.
2 How did you a plaster ring on a 2 gang plastic nail on box?
Code05 is offline   Reply With Quote
Old 05-29-2013, 01:16 PM   #141
E2 Electrician
Originally Posted by Code05 View Post
Stickboy,
It's not all my work, the plumbers do that **** all the time, and I used a 4" sq. new work plastic, not a 2 gang switch box.
Old 05-29-2013, 01:43 PM   #142
Code05's Avatar
I was just teasing on the 110.26 thing, figured it was existing anyways.
I do little resi and have not seen that box before. Are they common?
Old 05-29-2013, 02:09 PM   #143
E2 Electrician
Most of the houses I do want the receptacles horizontal, it's the easiest way to accoumplish this. Just turn the mud ring. the boxes are very common.
Old 05-29-2013, 02:18 PM   #144
Code05's Avatar
I have put recs in a backslash horizontally, but never a regular wall. Interesting. Must be a local thing.
Old 05-29-2013, 02:52 PM   #145
E2 Electrician
It's not a local thing, just an architect thing. High end custom housing. You should see the stuff we do.
Old 05-29-2013, 05:47 PM   #146
E2 Electrician
Check out the set of prints on the house i'm wiring now....
Old 05-29-2013, 06:12 PM   #147
Licensed electrician
Rewards Points: 1,626
I would not want my switches mounted that low.
I would also consolidate the low voltage into one plate.
Old 05-29-2013, 06:29 PM   #148
Code05's Avatar
Cool, I wire these units for a living right now.
https://www.fas.org/man/dod-101/sys/...sh2013/110.pdf
Old 05-29-2013, 07:14 PM   #149
E2 Electrician
Jim, the switch locations are laid out that way for art work on the walls, to ensure there will not be an issue.
the telephone jack picture is just a generac graphic to show that height as well.
I just had a job meeting this evening with the homeowners, the switches have been raised, the receptacles lowered into the baseboard... its going to be a VERY long job....
Old 05-29-2013, 07:16 PM   #150
E2 Electrician
Very cool!
Why are switches placed furthest from light? cypherx Electrical 17 06-21-2012 05:48 PM
Replacing multi-use light switches jimclark Electrical 4 08-30-2011 02:05 PM
3-way switches, lights, and a photoelectric switch. Your thoughts? Fox Electrical 7 11-23-2010 10:08 AM
2 switches 2 lights line in through light 1 bldaz Electrical 9 12-24-2009 06:42 PM
3 switches 1 light. need 2 lights 2 switches. Im desprete s richards Electrical 6 07-19-2008 03:18 PM
