Two Industrial Ceiling Fans On One Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 01-17-2012, 06:50 AM   #1
two industrial ceiling fans on one switch
trying to get two Hampton Bay Industrial 60"ceiling fans to run on one: "FAN 4 SPEED CONTROL" the second fan runs slower than the first. tried series and parallel - same effect. each fan is 1.2 amps. used 14-2. granted: the control reads: "for one fan only" but for many years i've had the same setup in another section of my building that works perfectly fine: same two Hampton Bay Industrial 60" fans - same control ("for one fan only"). i'm thinking the control is faulty and or i should have used 12-2 wire? any ideas? thank you arusillon
arusillon is offline   Reply With Quote
Old 01-17-2012, 07:29 AM   #2
joed's Avatar
Rewards Points: 13,294
Faulty control won't make one fan slower than the other. Faulty control should have same effect on both fans. More likely wiring issue or fan issue.
The Following User Says Thank You to joed For This Useful Post:
arusillon (01-17-2012)
Old 01-17-2012, 09:05 AM   #3
Licensed Pro
Make sure the speed control on each fan is set to high.
The Following User Says Thank You to HouseHelper For This Useful Post:
Old 01-17-2012, 01:13 PM   #4
i worked on the fans a little while ago: took the control off and used a regular toggle switch and realized the fan further away was on reverse!? (can't believe didn't notice that before!) switched it over and then low and behold the other was reversing!? i switched that one and now they are both blowing down and both at the same speed. (i believe i have them wired in series now). with the toggle switch i can get them to blast pretty good but when i put the 4 speed fan control back on it seems i can only get high and low, and the high is not as high as with the toggle switch. my first question is: should i have used 12-2 instead of 14-2? and how can i have this exact same system in another section of my building that works like a champ!? at this point i must get up on a tall ladder and check to see if i was using 12-2 in that old system..? confusidely yours, ar
Old 01-17-2012, 04:57 PM   #5
Semi-Pro Electro-Geek
Rewards Points: 2,970
You must use the correct size wire for the circuit breaker that supplies this circuit. If it's a 20A circuit, you must use #12 wire. If it's a 15A, you can use #14. This does not affect the normal operation of the fans; it's a safety issue. The problem is that you must wire them in parallel. All loads in a building are wired in parallel, always. Always.
mpoulton is offline   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
two switch ceiling fan/ light question ifthenelsenull Electrical 4 12-29-2011 03:23 PM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-08-2011 11:00 PM
Ceiling Fan Circuit Problem G_S_DB Electrical 1 08-25-2010 06:24 PM
Wiring Ceiling Box to Switch graceandhayes Electrical 1 10-23-2006 05:02 PM
New Switch / Ceiling Fixture - Help nelrolo3 Electrical 1 03-12-2004 06:11 PM
