Two Hots, One Neutral? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-08-2013, 12:01 PM   #1
two hots, one neutral?
Looking at a main panel, I see 14-3 w ground coming in. black connected to breaker 1, red connected to breaker 2, and white/ground connected to the ground bus. Its not 220... wth? Is this legal/safe? Seems wrong to me, I thought every hot should have a dedicated "white" return.
fj5gtx is offline   Reply With Quote
Old 07-08-2013, 12:09 PM   #2
joed's Avatar
Rewards Points: 12,028
This is called a multi wire branch circuit MWBC.
The voltage between the black and red must be 240 volts. The breakers must handle tied or a double pole breaker so that both off together. If installed properly(240 volts between hots) they are perfectly safe. WE use them all time in Canada for kitchen counter split wired receptacles.
The Following User Says Thank You to joed For This Useful Post:
fj5gtx (07-09-2013)
Old 07-08-2013, 12:28 PM   #3
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
If it was installed prior to the 08 code adoption, it's legal unless it supplied a receptacle with the tabs broken.
wirenut1110 is offline   Reply With Quote
Old 07-08-2013, 12:36 PM   #4
I just checked with my volt meter, the red and black is 240v apart... but on separate half breakers, many slots separated. House was built in PA, circa 1988. I have 3 of these circuits, none of them have tied handles or are marked in any special way.
Sounds like its electrically safe... but I'll be adding other circuits that will cause an inspection, what should I do to make these 3 circuits pass that inspection?
Thanks!
Old 07-08-2013, 12:42 PM   #5
Rewards Points: 510
As long as you're not doing anything with those circuits they're fine as is. You can't be made to bring something up to code that was legal when it was installed. It's called "grandfathered"
The Following User Says Thank You to wirenut1110 For This Useful Post:
fj5gtx (07-09-2013)
Common Neutral in Jct Box??? PastorKramer Electrical 5 11-20-2012 07:10 AM
No neutral bus bar in 220v sub panel! to3032 Electrical 10 07-04-2012 03:29 PM
Splicing Aluminum to Copper Wire dc4nomore Electrical 28 05-08-2012 02:56 PM
installing new dedicated circuit - neutral bus full 7green Electrical 12 05-03-2011 02:32 PM
Main disconnect neutral wiring Daniel Holzman Electrical 5 10-04-2009 02:36 PM
