Two Hot Wires ( A Brown And Black) To Power A Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 09-11-2012, 02:54 PM   #1
Two hot wires ( a brown and black) to power a switch
the switch is a dimmer for a light in a bathroom want to put afan on the switch but it has a white and black wire howto do this?
doverhol33 is offline   Reply With Quote
Old 09-11-2012, 03:01 PM   #2
Insatiable Learner
Rewards Points: 166
Smile
Is it JUST a dimmer, or a dimmer and switch? Part numbers? Pictures?
If it's just a dimmer then you cannot 'dim' a fan. You need a special fan control for that.
AngelArs is offline   Reply With Quote
Old 09-11-2012, 05:19 PM   #3
Resi EC
Rewards Points: 252
Sounds like a switch loop with just a black and white wire in the switch.
Might not be easy, but you'll need to run more wires.
Were you planning on the light and fan coming on together?
Gac66610 is offline   Reply With Quote
3-way switch on stairs won't work km3t Electrical 10 07-04-2012 04:09 AM
Changing 2 way switch to control light, not outlet? andysam Electrical 0 05-30-2011 09:20 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Another 3-way switch problem. speedster1 Electrical 6 01-16-2010 07:01 AM
installed recessed lights but now switch does not work auggie77 Electrical 2 08-02-2009 10:11 AM
