Old 04-08-2012, 01:18 PM   #1
two hot switches to same appliance
can i run a hot wire from a switch to a cooler & another hot wire from the same source thru another switch to the cooler & an exhaust vent? sometimes both switches would be on. does that double up the amps or trip the breaker or ?
51grizzly is offline   Reply With Quote
Old 04-08-2012, 01:54 PM   #2
Super Moderator
Don't do that--if both wire are from different legs in the breaker box you will have a 240 volt short.
If they are from different breakers ,but same leg--you will energize the entire circuit when one breaker is shut off.
What are you trying to do? Would a simple 3-way switch circuit work for you?
51grizzly (04-08-2012)
Old 04-08-2012, 04:29 PM   #3
it's a commercial hood vent w/cooler & exhaust that come on at the same time w/one switch. trying to turn on the cooler separately, but then the cooler & exhaust need to come on w/one switch.
a 3-way switch would work. didn't think of it. off/cooler/both!
MANY THNX!
The Following User Says Thank You to 51grizzly For This Useful Post:
oh'mike (04-08-2012)
Two 3-way switches, one acting as a master switch? Ler0y Jenkins Electrical 10 02-28-2012 01:01 PM
Wall Switches - with unknown termination cbjr Electrical 6 02-21-2012 09:15 PM
Replacing old switches RyanS2000 Electrical 4 09-11-2011 04:21 PM
2 Lights & 3 switches, doesn't look right curious1 Electrical 1 10-26-2010 11:26 PM
Need help replacing switches in four-way circuit magnolia Electrical 3 05-09-2008 10:40 PM
