Two Hot Circuit Same Breaker?? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-08-2012, 12:13 PM   #1
Rewards Points: 77
Two hot circuit same breaker??
Hello again friends,
So upon inspection of my Main panel 200A service, I can see that on my GFI breaker, there are two black wires (hot) on the 1 breaker. It looks like whoever did this, joined both the outdoor receptacles and the bathroom receptacles on the same breaker. The white neutrals and pigtail from GFI breaker go to the neutral bus bar. Ground to Ground bar.
Is this legal or pose a threat? Was this done by a hack?
Have had the house 2 years, no issues.
It's Eaton BR style panel and breaker is 1 in 15A GFI.
Thanks,
~S
Skelleyman is offline   Reply With Quote
Old 11-08-2012, 12:18 PM   #2
Licensed electrician
Rewards Points: 1,506
I do not believe the BR breakers are listed to accept two conductors.
The circuit neutrals should connect to the GFI breaker, not the neutral bus. The GFI pigtails connect to the neutral bus.
Old 11-08-2012, 02:09 PM   #3
Rewards Points: 77
Sorry, I meant that they (neutrals) do connect to the breaker. So it has the neutrals connected to same neutral terminal and hots connected to the hot terminal. So I think what I have to do is create a pigtail for the hots and another for the neutrals and use this approach to correct this double tapped circuit issue?? Tie the neutrals together with wirenut and pigtail one to breaker, same with hots. Then leave the breaker pigtail connected to N bus bar? Is this correct?
Thanks,
Old 11-08-2012, 02:20 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 424
Thanks,
That is correct.
New wiring tripping breaker on another circuit? Kinggofg Electrical 11 04-26-2012 01:36 AM
Backfeed Circuit Breaker Knucklehead_BW Electrical 13 01-11-2012 09:17 PM
circuit breaker? blueandyellow Electrical 7 01-30-2011 10:27 PM
Circuit BReaker Question - breaker didn't trip and no power thru the circuit Ronin_67 Electrical 2 08-08-2008 06:06 AM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
