Old 05-03-2011, 01:49 PM   #1
Two heating zones in house -- thermostat question
Sorry but I am clueless with these things:
I have two heating zones in my house (one for each floor), and i want to replace the two thermostats with electronic ones. Are there any unusual steps I need to take, when installing the thermostats, due to the two zones?
thanks!
19mquinn79 is offline   Reply With Quote
Old 05-03-2011, 05:18 PM   #2
Usually there are no issues, just remove the old thermostat and wire up the new one the same way. Usually there are just two wires to connect although if the thermostat also controls air conditioning then there may be three wires.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 05-03-2011, 07:57 PM   #3
Lic Elect/Inspector/CPO
Just makw sure you match the wires.
If it is hot water than it is usually only 2 wires, if it also controls ac than you might have 4-5
This how it is usually with ac
White and red =heat red is jumped from rh to rc.
Most tstats the jumper is already installed
yellow= ac
green = fan relay
NJMarine is offline   Reply With Quote
Where should I connect the thermostat ? DIY_user HVAC 2 01-11-2011 01:36 PM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 11:09 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 03:28 PM
Question about repainting house outside randalg Painting 3 07-21-2006 05:10 PM
Brick and block house footer question. ourzoo Building & Construction 2 07-01-2006 03:57 PM
