#1 |
Graduate of Wiring 1-2-3
Two grounds making me nervous
I will be running electricity to an outbuilding soon. Four wires going 50Ft in underground conduit from the existing panel to a detached building. The ground rods are the next step but I've got something bugging me. This could have nothing to do with electrical safety or efficiency but while studying audio circuits I was taught to only ground in only one place to avoid ground loop. Now I'm putting in a second ground at the outbuilding, and I keep thinking current will flow from one ground to the other, even though they are 50 ft apart. If I turn on a speaker or tv in the outbuilding will it buzz? Am I blowing things out of proportion? Is there some attribute of signal to noise ratio or low voltage circuits that don't apply to detached garages?
#2 |
Electrical Contractor
Nothing to worry about.
Just make sure that the ground and neutral are separate
Yes I am a Pirate, 200 years too late. "Jimmy Buffett" |
#3 |
Curernt does not flow on the ground unless you have a fault. Current does not flow through the rods even if you have a fault. The rods are for lightning protection.
Do not PM with questions that can be asked in a forum. I will not respond. |
#4 |
Well there can be current between two grounds without a fault, but if electrolysis or telluric current were a common problem, electricians would know about it.
#5 |
You talking to me?
With audio work, you do a lot of things to avoid noise that is not considered with a power circuit. Each has it's own rules simply because of what they are.
#6 |
I=E/R
I think you are referring to a chassis ground when you are dealing with audio circuits. The term ground can have different meanings in different settings.
#7 |
You talking to me?
well, the thing is, that chassis ground is connected to egc. I understand Lurlene's point as it is typical procedure to connect drains at only one end of a shield. The justification as far as I understand is so that you do not create a pathway for other currents (that ground loop thing Lurlene was talking about) that might be running around in the audio equipment but only drain emf induced current that might be created as the shield is exposed to ambient emf.
#8 | ||
Licensed Electrical Cont.
Oh please. Not ground loops again.
Ground loops are NOT an issue or problem with construction electric. |
#9 | |
I=E/R
Two grounds making me nervousQuote:
#10 |
You talking to me?
maybe you can explain it to me but I'm not seeing the connection between ground loops and your transformer.
#11 | |
I=E/R
It is similar to an AC welder. The work "ground" clamp is not connected to the EGC. There is no current path between the primary and secondary sides. There are separate symbols to designate the two: The one on the right is chassis ground. |
#12 | |
#13 |
Yep, if the posters here haven't heard of problems with ground loop, then there isn't one. Thanks for your responses guys!
#14 |
You talking to me?
well corsair, if you want to argue a point, you really should use the proper symbols for your terminology.
this is a chassis ground symbol ![]() your symbol with the triangle pointing downward is a "signal ground" which is not the same as a chassis or earth ground. |
#15 |
You talking to me?
You must realize what the concern with a ground loop is. It is to avoid electrical noise on a system. Due to the fact we are not transmitting any sort of signal over the power lines, ground loops are not a problem. We actually do create ground loops in various ways. It's just that they are not a concern in a power system (at least in the type of system we generally are speaking of)
| Tags |
ground loop ![]() |
| Display Modes | |
| Thinking about making concrete pavers - a few questions | Luis C. | Building & Construction | 16 | 06-10-2011 06:45 PM |
| Need help making a 'back band' around window/door casing. | RickDel | Carpentry | 3 | 07-15-2010 04:13 PM |
| rough inspection grounds | bfan781 | Electrical | 8 | 04-12-2010 05:36 PM |
| Wire connector for grounds | 8roty | Electrical | 1 | 01-04-2010 09:56 PM |
| Making bear totum pole | Keith of Ronin | Landscaping & Lawn Care | 2 | 03-27-2005 02:22 PM |
