Two Ground Rods? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-27-2012, 09:55 PM   #1
two ground rods?
i have just read in an electrical reference book that states a 400 amp exterior service panel must have two ground rods spaced six feet apart. i have searched and searched in the NEC but cannot find that info anywhere. is this true and if so where in the codebook? the closest thing i can find is article 250.24 (3) and it is referencing dual feed services. it says one will do. this service will have one line side feed pair of 350 mcm or maybe 500. can't remember for sure what power company said, but it will not be two sets of parallel lines coming in. one or two ground rods guys?
buddy builder is offline   Reply With Quote
Old 12-27-2012, 10:02 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
At least one ground rod is required by code. In order to install only one ground rod, you must be able to prove that its resistance to ground is less than 25 ohms. If you cannot prove this, you need to install a second rod. Most people install two rods from the get-go because proving <25 Ohms is more difficult and more expensive than installing the second rod.
The Following User Says Thank You to k_buz For This Useful Post:
NJMarine (12-28-2012)
Old 12-27-2012, 10:08 PM   #3
thanks k buz. good advice. go packers. i just can't quite comprehend your last sentence unless you meant it's cheaper to do it at time of installation rather than a later trip. ???
Old 12-27-2012, 10:09 PM   #4
gotcha. thanks.
Old 12-27-2012, 10:13 PM   #5
k_buz's Avatar
The testing equipment is rather expensive and the testing is rather specific. It's much easier to drive the 2nd ground rod and be done with it.
Old 12-27-2012, 10:20 PM   #6
i can believe that. thanks so much.
Old 12-28-2012, 07:09 AM   #7
Rewards Points: 1,512
(Even if a contractor has to make a second trip to install the second ground rod, that total job will probably cost less than choosing instead a contractor who possessed the needed test equipment to prove that one rod is sufficient and who installed and tested the rod all in one trip.)
Old 12-28-2012, 08:20 AM   #8
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
The contractor would also have to wait at the job site for the EI to witness the test. Here in NJ I have three days to complete an inspection ( not that that is the norm) but it could happen.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Bosch 11245EVS Rotary Hammer Drill for Ground Rods tedallen Tools 0 06-02-2012 04:52 PM
Hilti TE 52 for Driving Ground Rods tedallen Tools 6 04-23-2012 09:34 PM
Parallel path to Ground - I'm confused as usual robertmee Electrical 13 04-03-2011 09:37 AM
Connecting new dishwasher and garbage disposal -- no ground wire in the conduits. arca Electrical 17 03-28-2011 02:06 AM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 04:02 PM
