Two GFCI's On One Circuit? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-23-2013, 10:30 PM   #1
Insatiable Learner
Rewards Points: 166
Question
Two GFCI's on one circuit?
I will be installing a new heated floor in my upstairs bathroom. The controller has built in GFCI. It will pull around 1/2 of an amp so it will be connected to the outlet in the bathroom, which will also be GFCI. Is this going to cause any issues? I thought I read on these forums somewhere that two GFCI's should not be on the same circuit...
AngelArs is offline   Reply With Quote
Old 03-23-2013, 10:35 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Every heated floor I've installed has required its own circuit.
Old 03-23-2013, 10:49 PM   #3
Insatiable Learner
Rewards Points: 166
Smile
Yes but they were probably pulling much more amperage.
The two companies that I'm looking at using (suntouch and laticrete) both say that a unit this small can be used with the outlet.
It's only 3 sq. feet
Old 03-23-2013, 10:49 PM   #4
Rewards Points: 258
the controller pulls 1/2 amp or the floor heater pulls 1/2 amp?
redman88 is offline   Reply With Quote
Old 03-23-2013, 10:54 PM   #5
k_buz's Avatar
Ok, I have to ask, why would you heat a 3 square foot section of flooring?
Old 03-23-2013, 11:35 PM   #6
A GFCI outlet has a line and a load connection. If you connect it to the line side, same connections as those powering the GFCI from the breaker, then you would not have the problem of one GFCI connecting into another GFCI.
Billy_Bob is offline   Reply With Quote
The Following User Says Thank You to Billy_Bob For This Useful Post:
AngelArs (03-24-2013)
Old 03-24-2013, 07:43 AM   #7
Insatiable Learner
Rewards Points: 166
Smile
Actually it's less than 1/2 of a amp (0.4). I believe it's rated as a total system (controller + mat) but I will double check with the manufactures on Monday so we can be clear.
Old 03-24-2013, 07:54 AM   #8
Insatiable Learner
Rewards Points: 166
Smile
2 reasons actually;
1) It's still a bathroom floor.
2) I'm using very expensive tile and I don't plan on ever retiling it again.
I'm trying to plan ahead. I have a heated floor in the main bath and everyone loves it.
The upstairs has "limited" heat and the floors get very cold.
Anything I can do to make those 3 a.m. visits to the bathroom more pleasant is a good thing
Old 03-24-2013, 08:04 AM   #9
Insatiable Learner
Rewards Points: 166
OK THANK YOU Billy_Bob for helping address the question. I am also installing a new sub panel upstairs so I'll have to check to see if one or two lines were run to the bathroom. I just assumed everything (light, fan and outlet) were run on the same line but I'll have to double check that. If it's two lines then I can tap the floor controller off the fan/light. If not then I'll have to see if I can tap off the GFCI controller and install a standard outlet.
Is it code that the bathroom - has to - have an outlet, or can I just not install an outlet at all, and avoid the whole mess?
Old 03-24-2013, 08:10 AM   #10
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
Thing is though, this is NOT a problem.
There is no issue with one GFI protecting another, other than when it comes to troubleshooting a ground fault problem.
The Following 3 Users Say Thank You to Speedy Petey For This Useful Post:
AngelArs (03-24-2013), brric (03-24-2013), stickboy1375 (03-24-2013)
Old 03-24-2013, 08:21 AM   #11
k_buz's Avatar
To be fair, I looked up the specs on one of the manufacturer's products as the OP didn't give specifics, but it did say that there could potentially be a problem.
If it were me, I'd put it on a separate circuit especially if there was a chance this was going to be added to. Is this bathroom being remodeled? Are the walls open? Is this getting inspected?
Old 03-24-2013, 08:27 AM   #12
Master Electrician
Rewards Points: 3,966
If it's only .5 of an amp, put it on the lighting circuit, not on the receptacle circuit.
brric is online now   Reply With Quote
The Following 2 Users Say Thank You to brric For This Useful Post:
AngelArs (03-24-2013), k_buz (03-24-2013)
Old 03-24-2013, 08:48 AM   #13
Licensed electrician
Rewards Points: 1,892
The OP will not get much room heating effect from the floor heat, but will remove the chill on the feet.
Old 03-24-2013, 09:55 AM   #14
Insatiable Learner
Rewards Points: 166
Smile
A problem with what? I saw nothing indicated in any of their literature regarding the unit that we will be using. 99% of the mats used are much bigger than the one we are going to use. In-fact, I will be cutting the one that we have in half because even the 3x2 mat is too big. Here is a direct link to their information. If you can find any problems with the mat that we will be using (0800-3602-2) please let us know.
http://www.laticrete.com/Portals/0/d...ts/lds6050.pdf
Old 03-24-2013, 10:14 AM   #15
Insatiable Learner
Rewards Points: 166
Smile
THANK YOU Jim! Yes we are not trying to heat up the bathroom, just make it more comfortable when walking on the cold floor with bare feet
THANK YOU Speedy Petey! I did not know this. I thought that feeding one GFCI off of another would cause one, or both of the GFCI's to constantly trip or cause other issues. If it is just a trouble shooting issue than that is not a big deal to worry about.
Did My GFCI Circuit Breaker Fail? Jazan Electrical 8 08-04-2012 03:44 PM
Dimming lights on one circuit, GFCI breaker tripped boatman537 Electrical 4 06-05-2012 10:43 AM
Changing a 3 way circuit...using recessed lighting box as a junction box? Oxymoron Electrical 1 12-07-2009 06:46 PM
Two Different Wire gages on Same Circuit OK? Lovegasoline Electrical 5 12-02-2009 05:00 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
