Two Feeds To One Circuit? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-28-2013, 10:54 AM   #1
Rewards Points: 948
Two feeds to one circuit?
A light on my garage had a feed to a 3way switch at the front door, 14/3 to a 3way switch at the garage door, and then 14/2 to the light.
I put in timer that turns the light on at sunset (which the timer calculates by date and latitude!) and off at 11:30. There was no room in the box by the front door, so I put it in at the garage; using a feed from another light in that box that is on the same circuit.
Can I attach one of the travelers from the switch at the front door to the wire going to the light? That way if I want the lights on when the timer has them off, I can just do it at the front door. I can't turn them off from the front door when the timer wants them on, but you can't have everything.
Any problem with this I am overlooking?
Toller is offline   Reply With Quote
Old 02-28-2013, 07:01 PM   #2
I'm confused as to what the set up is here.
I know its not related to your question, but be sure to be using breakers rated for 15 amp or less. No 20's here. Also, I've used those automatic switches and like them.
Maybe you can rephrase the situation and question?
chris_b is offline   Reply With Quote
Old 02-28-2013, 07:04 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Which timer did you buy exactly? Im sure they make a three way timer?
Old 02-28-2013, 07:20 PM   #4
I can't speak for the original poster, but I used one like this:
http://www.safetyed.org/ge7-daysmart...itchwhite.aspx
Around $29 at Home Depot. It has a button that goes over all of the small buttons so it is really easy to use and override once it is set up.
Dimming lights on one circuit, GFCI breaker tripped boatman537 Electrical 4 06-05-2012 11:43 AM
Bathroom Fan/Outlets on Same Circuit rjschwar Electrical 6 04-22-2011 11:56 AM
Changing a 3 way circuit...using recessed lighting box as a junction box? Oxymoron Electrical 1 12-07-2009 07:46 PM
Two Different Wire gages on Same Circuit OK? Lovegasoline Electrical 5 12-02-2009 06:00 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
