Two Family Duplex - Garage Wiring Question - Electrical - DIY Chatroom Home Improvement Forum
Old 06-22-2008, 12:31 AM   #1
I just finished reading this topic and have a few questions:
burying wire underground
For duplexes in the mid-west, specifically south-east WI, what does NEC allow and not allow for trenching high voltage (20or15A 120/240v) from the main dwelling to a garage?
Normally at a rental property, you just trench a new threaded metal conduit and use whatever was existing for the other tennant, so that you can split up external garage lights, garage door openers, outlets, whatever onto their correct service panel. Tenants hate paying for other tenants electricity.
I have not come across it yet, but I know it will come up in the next few years. Can I trench a 1-1/4" or 1-1/2" Sched 40-80 and run two THWN rated cables through it to both tennant's breaker pannels? I have always run a parallel 1/2" low voltage PVC to fish 18-4 or cat5 wires through for hard wired garage door opener switches etc.
Anyone that has read the NEC knows that it gets confusing with two or more service panels. I keep the NEC in my magazine rack in the main bathroom and have not found a clear explanation yet. I am wondering if someone that full times this, or has an answer can help me out.
Many, many thanks.
Moonlight24 is offline   Reply With Quote
Old 06-22-2008, 12:46 AM   #2
Double posting... I hope I don't mess this thread up.
Example, install two 12/3, 4 conductor THWN rated cables inside a conduit. Can I use the reds on each 12/3 to go to switches inside the rental, to turn on the exterior garage lights for each side of the garage?
My mind boggles paging through the NEC, and I am sure someone can explain this very easily.
Thanks again.
Old 06-22-2008, 10:31 AM   #3
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
225.30B1 may allow this if the halves of the garage are separated from each other. Is the garage one big space or is it divided into 2 sections by a wall?
John
jrclen is offline   Reply With Quote
Carport to Garage: Fire barrier question Grommet Remodeling 2 03-28-2008 04:18 PM
Question about insulating a garage forCcanadian winters trucker Building & Construction 3 02-08-2008 05:07 AM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
Question about ceiling joists in a garage allpraisebob Carpentry 11 12-14-2006 08:00 AM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 11:52 AM
