Two Electric Heaters Not Working - Electrical - DIY Chatroom Home Improvement Forum
Old 01-17-2009, 07:54 PM   #1
two electric heaters not working
hi, i have 2 rooms next to each other and both heaters doesnt work, one never worked the other on and off, we changed thermostats to see if that was the problem and that didnt do it. any ideas?
tskmercer is offline   Reply With Quote
Old 01-17-2009, 09:38 PM   #2
Rewards Points: 820
Sounds like you need an electrician.
The wiring needs to be checked out. Perhaps they were never wired properly.
If you decide to look at this yourself, be very careful. Shut off power at the breaker(s) before doing anything.
Most of the baseboard electrics are 220V, so there should be a double-pole breaker for the circuit.
Ultrarunner2017 is offline   Reply With Quote
Old 01-17-2009, 10:33 PM   #3
Electrician
ctsmiths's Avatar
Rewards Points: 150
Its possible that the high heat overload in the heat unit itself is bad and not allowing it to work. You need to take a voltage reading at the heat with the thermostat set at 50 so you know it it on and see what you get for voltage. BE VERY CAREFULL as KE2KB has said the voltage is higher with heat units as well as the amperage. You should see between 208 and 240 V AC between the two hot conductors ( black and red or black and white most likely) If you do the heat needs to be replaced if not you need to check back at the thermostat and see what you have coming in and going out. BUT BE CAREFULL
ctsmiths is offline   Reply With Quote
Old 01-17-2009, 10:38 PM   #4
Rewards Points: 820
You're talking 50C, right? 50F the heat would never turn on.
Old 01-17-2009, 10:41 PM   #5
Electrician
ctsmiths's Avatar
Rewards Points: 150
Sorry I mean 70, hit wrong key. Good catch
Old 01-17-2009, 10:42 PM   #6
Electrician
ctsmiths's Avatar
Rewards Points: 150
You could set it higher if you want to
Old 01-17-2009, 10:43 PM   #7
Electrician
It would turn on in the northeast at the moment...
chris75 is offline   Reply With Quote
Old 01-17-2009, 10:52 PM   #8
Electrician
ctsmiths's Avatar
Rewards Points: 150
cant wait till heat problems are not problems anymore
closing off outlets above electric baseboard heaters abieslas Electrical 6 11-20-2008 12:45 AM
ceramic electric baseboard heaters - opinions? abieslas HVAC 7 11-17-2008 06:31 PM
Electric receptacle in lamp post and flood light not working th31 Electrical 7 12-13-2007 08:46 AM
Removing Baseboard Electric Heaters gieriscm Electrical 12 11-12-2007 05:59 PM
Electric tankless water heaters; any experiences? moneymgmt Plumbing 14 05-15-2007 11:36 AM
