Two Dryers, Still No Heat-please Help? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-07-2013, 07:34 PM   #1
Two dryers, still no heat-please help?
Hello,
When I moved into my house there was already a dryer (electric) here left from the previous owners. The dryer would turn on and tumble but would not heat. My mother in-law bought us a new dryer for Christmas and it does the same thing now. I really think it has to do with the outlet. Please help me out any way you can, I really appreciate it.
Thank you,
Courtney
Courtney(: is offline   Reply With Quote
Old 01-07-2013, 07:42 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,904
You'll need to measure the voltage at the outlet. It probably is missing one of the two hot legs. The motor in the dryer runs on 120V, but the heater runs on 240. With only one hot leg, the dryer gets 120V to run the motor but not 240V for heat. Check the voltage between every set of pins in the receptacle and report back...
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 01-07-2013, 08:22 PM   #3
Electrical Contractor
kbsparky's Avatar
Blown fuse/bad breaker. Or loose connection somewhere between the outlet and the panel box.
Bet a dollar to a donut there is NOTHING WRONG with the old dryer
-KB
Old 01-08-2013, 01:32 AM   #4
" Euro " electrician
frenchelectrican's Avatar
Read this thread which I did cover the issue with the dryer and the receptale it will show the clear answer what it should be done and the answer I posted in that thread is 4 conductor recpectale type if you have 3 conductor receptale or it look differnt let me know I will post the correct one.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
NJMarine (01-08-2013)
Tags
dryer , electric dryer , outlet
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 05:28 PM
Heat won't stop running, just installed new thermostat NorthSidePK HVAC 28 11-01-2012 11:05 AM
dual fuel heat pump - no heat without propane sweetfarm HVAC 3 10-11-2012 09:07 AM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 09:34 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 08:37 AM
