-   -   Two dryers on one 220v circuit? (http://www.diychatroom.com/f18/two-dryers-one-220v-circuit-155443/)
MikeDobbs 08-31-2012 07:51 PM
When I moved into my house it came with a washer and dryer in the basement. I would like to install my washer and dryer (from a previous house) on the main floor to make doing laundry more convenient.
I would also like to leave the ones in the basement hooked up for doing really dirty loads that my wife doesn't want to mix with regular laundry (or a backup if the others fail).
What I need to know is if I can splice the existing 220v line to the upstairs location or if I need to run a new branch circuit. Normally I wouldn't put two appliances on the same circuit like this, but I'm thinking that since they are both electric dryers, and they will never be on at the same time- it shouldn't be a problem.
Thoughts?
Speedy Petey 08-31-2012 07:54 PM
It is legal, but WHY bother? IMO it certainly IS likely that they might be used at the same time. Do you have kids? :whistling2:
Jim Port 08-31-2012 08:09 PM
I would run a new cable instead of introducing a splice point in a high draw circuit.
k_buz 08-31-2012 08:41 PM
I would love to be able to use two dryers at the same time. The wash cycle is much quicker than drying the clothes. I think you will find that you will use both even if you don't plan on it.
MikeDobbs 08-31-2012 10:04 PM
Thanks everyone- I guess I'll go ahead and throw in a new branch circuit. If nothing else, when I sell the house someday, the new owners may not remember to only use one at a time :wink:
frenchelectrican 08-31-2012 11:16 PM
The other thing you have to remember is that you will have to use 4 conductor cord plus 10-3 NM cable this is only way you can add this per code requirement.
This above comment is used for electrique dryer.
Merci,
Marc
ddawg16 09-01-2012 05:29 AM
Is gas an option?
AllanJ 09-01-2012 05:38 AM
Not only does the wire size limit the amperes rating (and the breaker rating) for a circuit but the kind (shape and prong arrangement) of receptacle and the appliance(s) itself (themselves) have maximum circuit amperage ratings.
The plug on the appliance cord also implies a maximum circuit amperage rating, and you may not cut it off and substitute a plug rated higher.
A definite no-no. "Each dryer requires a 30 amp circuit so I will run one 60 amp circuit daisy chaining to two dryer receptacles."
rjniles 09-01-2012 06:49 AM
Originally Posted by AllanJ (Post 1000855)
A definite no-no. "Each dryer requires a 30 amp circuit so I will run one 60 amp circuit daily chaining to two dryer receptacles."
That would be a total code violation. The poster needs to run a new 30 amp circuit for the second dryer.
