Old 03-11-2010, 03:47 PM   #1
Two Dishwashers one one circuit?
So while preparing for the electrician, I ran two lines for two dishwashers...one for the basement, one for the kitchen upstairs. I was originally planning on giving each one its own circuit..well lo and behold I didn't buy enough wire for the upstairs. Is it ok if I splice the one downstairs and hook the upstairs line into it (in a junction box) and run two dishwashers on one circuit (15 amps)? Thanks.
whoanow is offline   Reply With Quote
Old 03-11-2010, 03:56 PM   #2
the wire is 12-2 and the amp is 15..but neither line is actually hooked up yet. I could easily run down and pick up 20 amps..as that is what the electrician is doing by installing the actually breaker...but the problem lies in the drywall..I'd have to remove some drywall to run the 2nd line for the 2nd dishwasher..which is what I'm trying to avoid...that and the cost of more 12-2.
Old 03-11-2010, 03:58 PM   #3
Rotaredom & Xtrem DIY'r
Scuba_Dave's Avatar
How much power does each one pull ?
Plug in or hard wired ?
Code indicates a dishwasher must have a dedicated circuit
And disposal can be connected on that circuit
Code also indicates each kitchen must be treated seperate
So appears you need a dedicated circuit for each
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/-ongoing-37438/
Please fill out Location in your profile(User CP), then we can answer your question
If a code reference is needed for one of my posts please access NEC 2008 & read
http://nfpaweb3.gvpi.net/rrserver/browser?title=/NFPASTD/7008SB
Scuba_Dave is online now   Reply With Quote
The Following User Says Thank You to Scuba_Dave For This Useful Post:
whoanow (03-11-2010)
Old 03-11-2010, 04:04 PM   #4
Both will be hardwired..not sure how much each will pull? I can look that up tonight...thanks...it looks like I'll be pulling down some drywall..argh. Washington DC if that matters.
Tags
one circuit?, two dishwashers
Changing a 3 way circuit...using recessed lighting box as a junction box? Oxymoron Electrical 1 12-07-2009 07:46 PM
Need a wiring diagram Mooreski Electrical 42 10-04-2009 12:29 PM
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 15 07-23-2009 03:40 AM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 08:59 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 09:09 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
