Two Devices On A 240v Circuit??? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-08-2010, 10:07 AM   #1
Two devices on a 240v circuit???
I bought an air compressor (15 FLA) last weekend that I need to install. I have a 50a 240v circuit w/ a single outlet in my garage. Would it be possible to hard wire the compressor into the existing circuit, while leaving the outlet installed for when I want to use my welder?
Or would it be better to just install a power cord w/ plug on the compressor and unplug it when I want to use the welder?
mopowers is offline   Reply With Quote
Old 10-08-2010, 10:29 AM   #2
Licensed electrician
Rewards Points: 1,486
While the voltage may be the same the compressor needs to be protected by a smaller overcurrent protection device. This could be a 20 amp 240 volt circuit wired with #12 wire.
Old 10-08-2010, 01:16 PM   #3
Thanks for the help Jim! Both machines require a 30a breaker. I just got off the phone with Lincoln Electric and Campbell Hausfeld.
Would it be possible to hardwire the compressor in while also having an outlet (knowing I would never use both at the same time). Or would it be better to just leave the one outlet and install a cord w/ plug on the compressor and just plug each one in as I need them?
FYI- This is for home use and I don't use each tool but maybe twice a month.
Old 10-09-2010, 07:57 AM   #4
Rewards Points: 1,494
Just my opinion, I would go with cord and plug usage.
Prevents breaker tripping if you forgot to turn off the hard wired compressor and it cycled on while you were using the plug in welder.
Planning circuit layout for barn tbeaulieu Electrical 8 04-08-2010 09:38 AM
Can't get the master circuit breaker properly seated davefoc Electrical 1 03-22-2010 06:17 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Open circuit has power, close the circuit no power??? BeginnerHomeDIY Electrical 7 07-08-2009 02:40 PM
Adding an outlet on a 240V circuit? Kjunk Electrical 6 05-31-2008 09:27 AM
