Two Ceiling Light Fixture Switches Suddenly Acting Flakey!!! - Electrical - DIY Chatroom Home Improvement Forum
Old 10-12-2009, 07:12 PM   #1
Two Ceiling Light Fixture switches suddenly acting flakey!!!
ok, I have two ceiling fixtures in the dining and kitchen. One is a chandelier, one is a floruescent tube, ( I think). Both fixtures were working like champs when we bought the house, there are TWO separate switches for each of the lights in TWO locations (so four switches in all). Now: All of a sudden, the switches, are acking really flaky...Sometimes the switches don't work, sometimes they do if I change positions, now one switch will turn ON the chandelier, and when I turn off the chandelier, it turns ON the kitchen light. it is not supposed to do this!! What gives?
babalina is offline   Reply With Quote
Old 10-12-2009, 07:17 PM   #2
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
Hard to see the exact issue with just this info and without knowing how it's wired, but I am guessing these are two way circuits (any switch can turn on or turn off the light at any time) and a wire somewhere got loose.
Turn off power and unscrew each switch and carefully pull it out to see if there's anything that seems loose. 3 way circuits can do interesting stuff if misswired, or a wire gets loose.
Old 10-12-2009, 07:19 PM   #3
300zx's Avatar
You say you didn't mess with the switches maybe put new ones in ? For what you are talking about is average for people who chanmhge out there rec and lights.
300zx is offline   Reply With Quote
Old 10-12-2009, 07:20 PM   #4
joed's Avatar
Rewards Points: 13,344
If they have worked perfect and you have not done any work on the electrical then probably a loose or open connection somewhere. I don't think a flaky switch could do this.
Old 10-12-2009, 07:34 PM   #5
that is correct, I didn't touch a thing, all of a sudden it was acting weird.
I bet there is a loose wire or two wires touching or something, I better call the electrician....
Old 10-12-2009, 07:52 PM   #6
Residential Contractor
Definately call a licensed electrician if you have not made any changes. You either have a neutral problem, or one of the travellers is touching a hot somewhere.
rselectric1 is offline   Reply With Quote
Tags
ceiling lights flakey
Help wiring ceiling light wylde8 Electrical 1 09-24-2009 06:29 AM
Problem with 5 light ceiling fan fixture wetsu Electrical 2 06-05-2009 08:22 PM
Light fixture in a drop ceiling? kosherdill Electrical 1 03-01-2009 12:23 PM
can't get new light fixture to work carolcwilson Electrical 24 08-12-2008 12:52 PM
Ceiling fan with light - 2 switches, one for fan, one for light vendejp Electrical 3 03-21-2008 05:33 PM
