Two Ceiling Light Fixture switches suddenly acting flakey!!!
ok, I have two ceiling fixtures in the dining and kitchen. One is a chandelier, one is a floruescent tube, ( I think). Both fixtures were working like champs when we bought the house, there are TWO separate switches for each of the lights in TWO locations (so four switches in all). Now: All of a sudden, the switches, are acking really flaky...Sometimes the switches don't work, sometimes they do if I change positions, now one switch will turn ON the chandelier, and when I turn off the chandelier, it turns ON the kitchen light. it is not supposed to do this!! What gives?
Hard to see the exact issue with just this info and without knowing how it's wired, but I am guessing these are two way circuits (any switch can turn on or turn off the light at any time) and a wire somewhere got loose.
Turn off power and unscrew each switch and carefully pull it out to see if there's anything that seems loose. 3 way circuits can do interesting stuff if misswired, or a wire gets loose. |
You say you didn't mess with the switches maybe put new ones in ? For what you are talking about is average for people who chanmhge out there rec and lights.
If they have worked perfect and you have not done any work on the electrical then probably a loose or open connection somewhere. I don't think a flaky switch could do this.
that is correct, I didn't touch a thing, all of a sudden it was acting weird.
I bet there is a loose wire or two wires touching or something, I better call the electrician.... |
Definately call a licensed electrician if you have not made any changes. You either have a neutral problem, or one of the travellers is touching a hot somewhere.
| All times are GMT -4. The time now is 06:29 PM. |
