Two Black Wires In Ceiling Fixture - Electrical - DIY Chatroom Home Improvement Forum
Old 06-20-2012, 01:36 PM   #1
Rewards Points: 53
Two black wires in ceiling fixture
Hi -
I am trying to install a new ceiling light in my upstairs hallway. The light (made by a company out of business with an instruction manual in a 2 font) has two black wires and no white wire. One black wire has lines on it (is that considered ridged?). The other black wire has small words printed on it in white.
I hooked the lined black wire to the white wire and the black wire with small words to the black wire from the outlet box. The light works fine, but is that correct?
majch is offline   Reply With Quote
Old 06-20-2012, 02:28 PM   #2
joed's Avatar
Rewards Points: 13,308
Should be fine. The ridged wire is the neutral.
Old 06-20-2012, 02:30 PM   #3
bubbler's Avatar
Rewards Points: 256
Originally Posted by majch View Post
Hi -
You should probably use a meter to check which wire is connected to which contact in the socket. The center contact in the socket is the "black" (hot) wire. The other would be the "white" (neutral). There should be close to 0-ohms resistance between one contact and one wire, and "open line" between that same contact and the opposite wire.
Better to figure this out by measuring... the light works with it reversed, but if the hot/neutral are reversed you run the risk of energizing the chassis if it's an older fixture or something goes wrong w/ the socket.
My advice is based on anecdotal knowledge or personal experience. I'm not a professional no matter how matter of factly I may say something
bubbler is offline   Reply With Quote
Old 06-20-2012, 02:56 PM   #4
Rewards Points: 53
What is the official name of the meter? ie - If i were to look it up on amazon, what's the full name?
Adding a wall switch to a pull chain fixture abacuslearns Electrical 17 12-20-2011 06:02 PM
Installing a pull chain ceiling fixture safron Electrical 16 08-22-2011 05:13 PM
Wiring a Ceiling Fixture cahinnbpt Electrical 1 07-04-2011 03:14 PM
if there are red white green and black wires coming out of your walls like everywhere cray331 Electrical 3 01-17-2011 12:56 PM
Ceiling Fan Install power source at fixture uaw239gm Electrical 17 01-09-2011 08:50 PM
