Two Appliances On A Single 15A Breaker. - Electrical - DIY Chatroom Home Improvement Forum
Old 02-27-2010, 01:49 PM   #1
Two appliances on a single 15A breaker.
Hi! Is it safe to run a 20 cuft freezer and a 3.5 cuft front load washer on a single 15A breaker with #14x2 wire.
Adnan is offline   Reply With Quote
Old 02-27-2010, 01:52 PM   #2
What are the power draws for each item ?
Old 02-27-2010, 02:01 PM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
it will probably just trip the breaker,can you run a seperate 20a circuit for one of the appliances?
plummen is offline   Reply With Quote
Old 02-27-2010, 02:12 PM   #4
joed's Avatar
Rewards Points: 13,696
Probably won't be a problem since the washer is very low usage item.
However if this is new wiring the laundry circuit needs to be dedicated to the laundry room only.
Old 02-27-2010, 02:39 PM   #5
My washer is listed as 7a, probably when it starts the spin cycle
My 11cu ft freezer is rated at 5a
It would really suck if the washer kicks the breaker off & you don't notice
So if you are going to do laundry don't leave the house
Old 02-27-2010, 02:46 PM   #6
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
is it safe?
yes. If the circuit is overloaded, the breaker will trip and all will be well, except for the food in the freezer.
Joed, being in canada would be one of the best sources here for what is legal or not.
is the installation a good idea?
I would say no. start up loads on either appliance would challenge the 15 amp breaker and then if the other appliance is running at the same time "pop goes the breaker".
Personally, I would never do it and recommend that it not be done. Too much chance of costing you more in lost food than what it would take to run another circuit.
Circuit Breaker, working in reverse dcwestcott Electrical 4 04-06-2009 03:03 PM
Tandem Breaker and Circuit(s) whowadat Electrical 1 01-09-2009 04:13 AM
I can "double" the wires to each breaker in my breaker panel right? Piedmont Electrical 40 10-01-2008 11:18 AM
How Does A Double Pole Circuit Breaker Trip? shadowx360 Electrical 2 07-09-2008 02:44 PM
single vs. double breaker Neil_K Electrical 3 11-14-2004 11:02 PM
