Two 3 Way Switches For Outside Lights. Timer Install - Electrical - DIY Chatroom Home Improvement Forum
Old 06-20-2011, 11:47 AM   #1
two 3 way switches for outside lights. Timer install
Two three was switches. One inside, one in garage. Inside switch wired..common (into the White/brass screw), black to black screw and red to another brass screw, ground to ground. similar connections at the garage switch. Timer has R,W,B,G...appears no combination of connections works..do I need a jumper or just doing something wrong? And where should the time be, garage or inside?
Thanks very frustrating
DP47va is offline   Reply With Quote
Old 06-20-2011, 11:59 AM   #2
Licensed Pro
If all you have at each switch are the wires connected to the switch, it won't work... the timer needs a neutral which you don't appear to have.
The Following User Says Thank You to HouseHelper For This Useful Post:
DP47va (06-20-2011)
Old 06-20-2011, 12:05 PM   #3
" Euro " electrician
frenchelectrican's Avatar
What the model number of that timer switch ?? due some of the timers you will have to use real netural not the remarked white { common to use on 3 way switch useage } the only way you can snag a legit netural if you look inside the switch box you should see extra netural conductor in there.
If not sure then try to take a photo and upload it here and we can go from there as well.
However let me warn you with the timers if you get one without netural connection becarefull with bulb slection some of the timers will NOT work with LED or CFL bulbs.
Merci.
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
DP47va (06-20-2011)
Old 06-20-2011, 12:22 PM   #4
Timer
Timer is a UtiliTECH #0192773
Old 06-20-2011, 12:27 PM   #5
Timer
Can I get a neutral WHITE wire directly from the 'twist' connector of other whites in the box..going to the another switch in the box? There are other wires in the junction box ..actually three with w-b and one with w-b-r
..or why so much confusion ..I've seen several diagrams even several claiming to use jumpers.
Old 06-20-2011, 05:15 PM   #6
joed's Avatar
Rewards Points: 12,332
You need a three way timer that does not require a neutral. I don't think that timer will work for your application. It it is only a single pole timer.
The Following User Says Thank You to joed For This Useful Post:
DP47va (06-20-2011)
Old 06-20-2011, 08:37 PM   #7
I did do a little digging and that timer is NOT a three way at all so you will have to exchange for correct three way timer useage { make sure you get one sans netural conductor requirment}
Merci.
Marc
DP47va (06-20-2011)
2 Switches / 2 Lights / 1 Receptacle RickyBobby Electrical 6 05-12-2011 01:46 PM
How to install flood lights above a shed whatrymes Electrical 6 05-08-2011 03:23 PM
Basement lighting circuit - multiple lights and switches, end of circuit cmyk Electrical 2 03-03-2011 02:39 PM
3 switches 1 light. need 2 lights 2 switches. Im desprete s richards Electrical 6 07-19-2008 03:18 PM
Help... Trying to install can lights on the first floor of a two story house... whutitdew25 Electrical 5 03-17-2008 12:51 AM
