Two 2-wire Cables Legal In Three-way Circuit? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-27-2012, 11:30 AM   #16
Rewards Points: 266
The way it was commonly done is use one cable as a constant power and neutral, and the other cable as the two travelers. I don't see it being a problem if they are ran next to each other as they sound like they are. What you don't want is the two cables taking different paths through the house, which produces an EM field becuase the hot (travellers) and neutral are not ran together. This was done sometimes when the cable carrying the hot and nuetral came from a different box as the one carrying the three way & travelers.
The part that I don't understand is when you say "use both whites as neutral."
junkcollector is offline   Reply With Quote
Old 03-27-2012, 04:23 PM   #17
Rewards Points: 330
Originally Posted by joed View Post
Certain wiring configurations of three ways are switch loops. The ones with power feed at the fixture are switch loops. The ones with power feed at one switch going to second switch and then fixture are not switch loops.
i'll go for that.just took a while to catch what you said.
oleguy74 is offline   Reply With Quote
Old 03-27-2012, 04:32 PM   #18
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
reconsidered the example
Old 03-27-2012, 05:37 PM   #19
Thanks, everyone, for the replies. I'm less than clear, but I think the consensus is that it's not a great idea, but probably legal. In any case, I've finally found an electrician who will return my calls, so hopefully I'll make it his problem.
Terry
TerryR is offline   Reply With Quote
Old 03-27-2012, 05:47 PM   #20
joed's Avatar
Rewards Points: 12,362
Originally Posted by k_buz View Post
Would you consider this legal?
hot comes to one of the 3way switches
a 2 wire to the 2nd 3way containing the travelers
a 2 wire to the 2nd 3 way containing either the hot or the switch leg and the neutral
switch leg comes out of the other 3 way switch
If not, why?
I would not because there is a code rule that says hots and neutral must be in the same cable or conduit or raceway. You have split the hot and neutral into two different cables.
Old 03-27-2012, 05:49 PM   #21
I don't understand that with the power being supplied at the switch. Don't I just need a neutral and two travelers?
That's right. Both cables come from the switch box, and run down the wall together (under the same staples, I'd guess). They come into the ceiling of the unfinished basement, where I'd run them into a box and wire a 14-3 to the other switch, and a 14-2 to the load.
I figure I need the two blacks as the travelers, and one white as the neutral. So I have a second white, which could either be ignored, or joined with the other white. I figured joining them together was better, but maybe not?
Terry
Old 03-27-2012, 05:50 PM   #22
k_buz's Avatar
I deleted the example because it was a poor example...sorry.
Mixing 14/2 and 12/2 wire on one circuit? dekohl Electrical 12 03-13-2012 07:19 AM
Sharing Neutrals on the same phase electro Electrical 30 08-12-2010 02:10 PM
Decommissioning old armored wire circuit toddmanqa Electrical 6 12-04-2009 08:55 AM
Tying in aluminum wire to copper wire...legal? safe? I_think_I_conduit Electrical 2 11-06-2009 05:38 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
