Two 2-wire Cables Legal In Three-way Circuit? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-26-2012, 07:47 PM   #1
Two 2-wire cables legal in three-way circuit?
I have two unused switches in a wall (installed for future use, never used). Each has a 14-2 cable running to a box in the unfinished basement, where they were intended to connect to a future load. Power is supplied from the wall box where the switches are. I want to install a three-way switch in place of one of them, leaving the other unused. It's difficult to get to the base of the wall to pull in a 14-3, so I'd like to avoid that.
Can I legally use the black wires of the two 14-2s as the travelers, and both whites as the neutral, to the box in the basement, where I'd wire the rest of the circuit conventionally?
Terry
TerryR is offline   Reply With Quote
Old 03-26-2012, 08:56 PM   #2
Rewards Points: 6,652
Yes you can do that, but it is a PITA, and on the offside if the next person that comes along is not aware of how it is wired, there could either be some fireworks, or a whole lot of cussing, when they can not get the circuit to work. Make sure that you code which wire is the traveler.
Old 03-26-2012, 09:44 PM   #3
Rewards Points: 330
don't think so.300.5(I) says conductors of the same ckt and where used grounded conductors and grounding conductors shall be installed in same cable or raceway.I know we can't do it here...
oleguy74 is offline   Reply With Quote
Old 03-26-2012, 10:12 PM   #4
You can run two runs of Romex for a three way, but it becomes a PITA as I already stated, due to the next person will not know how it is hooked up, and try to do something differently. This actually becomes a gray area under that section.
Old 03-26-2012, 10:15 PM   #5
Rewards Points: 330
well do what you want.
Old 03-26-2012, 10:15 PM   #6
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
The wires between two 3 way switches aren't classified as a circuit, they are a switch loop.
Old 03-26-2012, 10:17 PM   #7
Rewards Points: 330
if you say so.a three way is not a switch loop.
Old 03-27-2012, 06:20 AM   #8
Rewards Points: 1,548
However two cables (14-3 and 14-2) running between the same two boxes may be needed to comply with the latest National Electric Code regarding providing a neutral in each switch box. A homeowner or electrician might not find it convenient to obtain 14-4 Romex for 3 way switches.
Old 03-27-2012, 07:16 AM   #9
Well then. Show all of us how it is not.
Old 03-27-2012, 07:17 AM   #10
It is a legal way of doing it, and fits within the code.
Old 03-27-2012, 07:38 AM   #11
joed's Avatar
Rewards Points: 13,728
Certain wiring configurations of three ways are switch loops. The ones with power feed at the fixture are switch loops. The ones with power feed at one switch going to second switch and then fixture are not switch loops.
Old 03-27-2012, 07:47 AM   #12
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,264
While I agree it is done and not many inspectors will gig you for it, I do not think it meets the requirement of 300.5(I). Switch legs are part of the circuit.
Additionally the requirement in NEC 2011 to carry a neutral to all switch boxes will eventually enforce the use of 4 wire cable (14/4 or 12/4). Running 2 cables to get the neutral to all switch boxes will be deemed a violation of 300.5(I).
Coastal South Carolina
Old 03-27-2012, 08:17 AM   #13
Rewards Points: 330
in most situations,a switch loop,the use of the neu.side of a 12 or 14-2 is used for hot to sw and black returns to load.useing a single pole sw.to three way from a fixture box,you only need to sw the hot so neutral is not carried to sw box to carry power as a hot so unless you use the neu as part of switched hot, this not a switch loop.just my view. as to weather or not it is deemed ok for you to do it or not is fine just as said not a good method.
Old 03-27-2012, 08:25 AM   #14
I do not see how this will be a violation of 300.5(i). I just looked at it, along with the other two sections that go along, and no where do I see that it will be in violation.
As for switch loops, that will and always has been the nature of the beast, especially when people start introducing technology, due to their lazy butts can not get up and turn on or off lights.
Old 03-27-2012, 08:27 AM   #15
Yes, it is not a good method of getting the job done, but it meets code guidelines, and I am stressing on the word guideline.
Mixing 14/2 and 12/2 wire on one circuit? dekohl Electrical 12 03-13-2012 07:19 AM
Sharing Neutrals on the same phase electro Electrical 30 08-12-2010 02:10 PM
Decommissioning old armored wire circuit toddmanqa Electrical 6 12-04-2009 08:55 AM
Tying in aluminum wire to copper wire...legal? safe? I_think_I_conduit Electrical 2 11-06-2009 05:38 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
