Two 120v Nuheat Mats Wired In Series For 240v Circuit? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-25-2010, 10:07 PM   #16
Electrical Contractor
kbsparky's Avatar
Wiring them in series is not a good idea, since the resistance of each mat is different.
Read this thread for some real-world test results when operating different loads in series. The thread deals with a lost neutral on a multi-wire circuit, but the results are the same as intentionally wiring them in series as you are proposing.
-KB
Old 04-25-2010, 10:12 PM   #17
Originally Posted by brric View Post
Can you show us what article requires supply circuit ahead of the TS to be GFCI protected?
He's referring to the fact that some manufacturers do not have t-stats that are GFCI rated for personnel protection (Class A, 5mA trip), but rather have "Ground Fault Protection" in which GFCI protection is not there, and is required for use in a bathroom floor.
The NuHeat SOLO is true Class A GFCI, so it's good to go.
Willis
williswires is offline   Reply With Quote
Old 04-25-2010, 11:25 PM   #18
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
chrispy35;433372]Thanks for the quick replies all, I have a few follow-up statements and questions:
I'm not sure I understand your statement regarding both mats being the same size. Do you mean same power rating? Mat #1 is 120 W @ 1.0 A (120 ohms) and mat #2 is 90 W @ 0.8 A (160 ohms). Wired in series, these two would create a 280 ohm load that would produce 205 W of heat on a 240 V line which is marginally less than if they were wired in parallel to a 120 V line.
that blew it right there. If you hook 2 devices in series and they are not equal in resistance, the voltage will not divide equally between them. It will be proportional based on the percentage of each device compared to the total resistance.
if my calcs are correct, you will have 140 volts across one mat and 100 volts across the other.
Old 04-27-2010, 12:16 AM   #19
Excellent link Sparky. I should have thought of that right away.
Thx everyone. Re-wiring is going to be much cheaper than re-doing the floor so that's the way I'll go.
Chris P.
chrispy35 is offline   Reply With Quote
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Replacing a switch wired in series? bmoorhouse Electrical 11 04-19-2009 08:04 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 08:59 PM
light switches wired in series -- why? magnolia Electrical 2 05-11-2008 12:16 PM
Parallel vs. Series Circuit johnson217 Electrical 1 06-19-2005 11:03 PM
