Twisting Wires Inside Box - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-02-2012, 07:36 AM   #16
Rewards Points: 398
Actually I used needle nose to twist the exposed ends together(which also in turn twisted the wires some) then added the wire nut until it was tight (without allowing the wires to twist) then once tight just kept twisting it by hand for a little bit more allowing the wires to follow.
I only added one 14-3 wire and a second switch to the mix all of the other wires were original from the home builder. I tried to follow his length and thought twisting them would save me some space in the box since the fan speed switch is rather big and was hard to fit into the box with all those other wires laying around.
Central New Jersey Area
adgjqetuo is offline   Reply With Quote
tool for twisting really short threaded nipples from inside amakarevic Plumbing 2 08-11-2011 06:30 PM
Neutral Wires Hot Problem rayray221 Electrical 7 09-20-2010 11:20 AM
Ceiling Fan installation, 3 sets of wires in ceiling southnam Electrical 3 09-13-2010 03:00 PM
Is this normal? 20A circuit 20A wires feed 15A wires walt1122 Electrical 14 02-06-2010 02:44 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
