Twisting Wires Inside Box - Electrical - DIY Chatroom Home Improvement Forum
Old 08-31-2012, 06:31 PM   #1
Rewards Points: 398
Twisting wires inside box
Is it ok to twist wires like this inside a box?
adgjqetuo is offline   Reply With Quote
Old 08-31-2012, 07:35 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
It is not a code violation but it looks amateurish. Also, don't leave so much cable sheath in the box (1/4-1/2" is plenty). But not nearly as bad as this.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 08-31-2012, 07:51 PM   #3
Licensed electrician
Rewards Points: 1,296
The tabs in the back of the box are supposed to hold the cable in the box. They should not have been broken out. The box should be replaced.
electures (09-01-2012)
Old 08-31-2012, 08:54 PM   #4
A "Handy Husband"
rjniles's Avatar
Jim,
Can you see that in the photo the OP posted or in the second photo that I posted?
RJ
Old 08-31-2012, 09:04 PM   #5
bbo
Originally Posted by rjniles View Post
Jim,
RJ
I can see that in the OP photo.
either that or they didn't thread the romex in the right way.
look at bottom left inbound wire.
bbo is offline   Reply With Quote
Old 08-31-2012, 09:04 PM   #6
Rewards Points: 398
I think he's talking about my photo. The one tab on my box is broken off. I know it should be replaced but I honestly don't feel like taking apart all those wires and redoing everything right now. I know it's not correct, but at the same time the wire isn't going to go anywhere.
Old 08-31-2012, 09:07 PM   #7
Jim,
RJ
Posted by the Op, bottom of box, white cable.
Old 08-31-2012, 09:52 PM   #8
A "Handy Husband"
rjniles's Avatar
OK I see it now. You guys have a lot better eyes than mine.
Old 09-01-2012, 01:00 AM   #9
DIY Enthusiast
In single gang boxes aren't you allowed to break out the tabs? I know several of those boxes only have break outs, not the bendy tabs. I think the caveat is that you have to staple the wire within 8" or something to that effect.
Anyways, it annoys the crap out of me when wires are all twisted up like that. In my house the last guy to work on the electrical twisted everything up similar to the picture and the result is that most of the time I have to cut and expose fresh wire because if I try to un-twist the copper snaps off...
ajmckay is offline   Reply With Quote
Old 09-01-2012, 08:32 AM   #10
In some single gang nail-on boxes there are only knock-outs, no clamp. As you mentioned, in this situation you have to staple the cable closer to the box.
As for the OP, I HATE seeing things like that because it's so hard to work on. Twist the wires until there is one or two twists down past where the skirt of the wire nut goes to, that's all you need. Anything more simply makes it harder to shape into the box and much harder to work on later.
Also, it's a big pet peeve of mine to see cable insulation in the box. There is no need, cut it off where the cable enters the box.
Wow, I am a Negative Nelly today
NECHater is offline   Reply With Quote
Old 09-01-2012, 11:25 AM   #11
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Twisting the conductors is fine, but that is a little overdone. It can cause a little stress on the conductors. I have seen broken conductors from twisting too tight. A real pain-in-a$$ to trouble shoot. Although the installation instructions for the wire connectors do not require twisting, I prefer twisting the splices just a little. Enough so the splice doesn't come apart while trouble shooting (not my work).
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 09-01-2012, 11:26 AM   #12
electures's Avatar
This picture just screams "trunk slammer".
The Following User Says Thank You to electures For This Useful Post:
jbfan (09-01-2012)
Old 09-01-2012, 03:12 PM   #13
Rewards Points: 1,444
Isn't it code to leave a certain amount in the box? Between 1/2 an inch and an inch or so?
mikegp is offline   Reply With Quote
Old 09-01-2012, 03:43 PM   #14
.25 inches, and there is no reason for any more than that. If a little more comes thru by accident, fine. But there is no reason for 1 inch or more sheath to be in the box. It simply makes no sense, it's like taping wirenuts, the only people who do it are people who shouldn't be doing electrical work.
Old 09-01-2012, 04:55 PM   #15
Electrical Contractor
jbfan's Avatar
Rewards Points: 256
Looks like the wires were twisted with a drill!
tool for twisting really short threaded nipples from inside amakarevic Plumbing 2 08-11-2011 07:30 PM
Neutral Wires Hot Problem rayray221 Electrical 7 09-20-2010 12:20 PM
Ceiling Fan installation, 3 sets of wires in ceiling southnam Electrical 3 09-13-2010 04:00 PM
Is this normal? 20A circuit 20A wires feed 15A wires walt1122 Electrical 14 02-06-2010 03:44 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
