Twisting Wire Into Existing Splice - Electrical - DIY Chatroom Home Improvement Forum
Old 08-18-2010, 02:53 PM   #1
Rewards Points: 91
twisting wire into existing splice
I want to add another branch to an existing junction box, where three wire runs are already spliced together. Is there any trick to splicing in another wire into the already twisted wires? Do I need to undo the twists or just wrap the new wire around them? I feel like any additional twisting of the existing wires will weaken them further.
debiasio is offline   Reply With Quote
Old 08-18-2010, 03:12 PM   #2
Mad Scientist
Generally I just lay the new wire along the existing spiral of wires, in line with the twists, and give it a twist with lineman's pliers to twist it into the existing splice. Hope that makes sense... You may need to go up to a larger wirenut, and you will also need to verify that your new wires don't exceed the box fill limit for the junction box.
McSteve is offline   Reply With Quote
Old 08-18-2010, 03:14 PM   #3
Electrician
Proby's Avatar
This is one of the reasons why I recommend people leaving their wires nice and long. In a perfect world I would cut off the splice, re-strip each wire, and twist them all up nice and new. I personally don't like twisting, untwisting, re-twisting, etc.
If you don't have enough wire to cut it off and start fresh, it's not the end of the world.
What I usually do is strip the new wire longer than usual, maybe an inch and a quarter of bare conductor. I then hold the new wire next to the existing splice making sure that the insulation on all of them line up and I hold it tight. Then I grab the end of the new wire with my linemen's pliers and pull it around the existing splice so it fits into a groove. After it's threaded up to the end of the splice, I grab the entire splice and give it a twist for tightness, then cut off any extra wire sticking out the end.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
The Following User Says Thank You to Proby For This Useful Post:
McSteve (08-18-2010)
Old 08-18-2010, 03:16 PM   #4
Mad Scientist
Well said, Proby. This is exactly the process I was trying to describe. Your explanation is much clearer and specific.
What is the best way to wire this? RST Electrical 8 08-19-2009 12:29 AM
Running new wire in existing wall Rdakota06 Electrical 5 07-30-2009 03:57 PM
Is using a ground wire as neutral wire safe? Head Fred Electrical 9 12-18-2008 03:37 PM
replacing old wire on existing circuits... red86yota Electrical 9 12-08-2008 07:00 PM
How to wire a 2-prong lamp to a ceiling mount with an existing ground cyantific Electrical 1 08-19-2008 06:22 PM
