Twisting wire for higher voltage
FYI....twisting the wire will actually add to the length....and be counter productive. You see stranded wire twisted because that allows it to bend without breaking. If there was no twist....it would be about par to trying to bend solid wire.
Common Sense is like Deodorant. Those that need it the most don't use it.
My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
