Twisting Romex Pigtail - Electrical - DIY Chatroom Home Improvement Forum
Old 12-29-2011, 07:08 PM   #1
Twisting romex pigtail
What is your opinion?
I am not a licensed Electrician,a do it your selfer.
I am old school trained, every permit that I pulled passed inspection first time out.
Here is the question:
I was trained to twist romex pigtail with linemen pliers and then screw on a wire nut.
I see a lot where the wires are just held together with the wire nut. The theory is that the wire nut has the metal spring in them now and that mechanical connection is all that is needed.
What is code? What is your opinion?
I will still twist first!
Hardway is offline   Reply With Quote
Old 12-29-2011, 07:12 PM   #2
Rewards Points: 582
I agree with you linemans twist install wire nut ....don't think thats part of any code in electrial that I know of....ben
Old 12-29-2011, 07:20 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 554
No code other than follow the directions on the box.
I pre-twist.
The Following User Says Thank You to jbfan For This Useful Post:
ben's plumbing (12-29-2011)
Old 12-29-2011, 07:23 PM   #4
MarginallyQualified
Rewards Points: 2,464
Originally Posted by Hardway View Post
I was trained to twist romex pigtail with linemen pliers...
If you don't... you can't get the solder to flow and hold the joint right.
Don't forget the tape!
Old 12-29-2011, 07:53 PM   #5
Electrician
SD515's Avatar
Rewards Points: 504
Here we go with this debate again.
I usualy don't pre-twist. By the time it's done, it's twisted anyways.
Kyle
The Following User Says Thank You to SD515 For This Useful Post:
Jim Port (12-29-2011)
Old 12-29-2011, 08:01 PM   #6
joed's Avatar
Rewards Points: 13,368
The I have say no pretwisting required. I do not twist.
Old 12-29-2011, 08:05 PM   #7
Missouri Bound's Avatar
That's a joke....right?
The Following User Says Thank You to Missouri Bound For This Useful Post:
Old 12-29-2011, 08:36 PM   #8
MarginallyQualified
Nope.
Not that I do it or ever did... but it used to be the common practice.
The linemans twisting is a carryover from that.
The Following User Says Thank You to TarheelTerp For This Useful Post:
gregzoll (12-30-2011)
Old 12-29-2011, 08:37 PM   #9
PreTwist
I was being trained by my Father at ten years of age, as a helper. I learned the codes over the years by reading NEC book and still learning as the codes change. pulling wire for forty years. Pretwist, never have/had a bad connection.
Thanks for the responses.
Old 12-29-2011, 08:45 PM   #10
Pre twist.
It is safer and a stronger joint.
Frank67 is offline   Reply With Quote
Old 12-29-2011, 09:17 PM   #11
Mad Scientist
I'll pretwist for more than 3 wires, otherwise I just make sure the wirenut is bottomed out, and give it a quick tug test.
And then of course I give it a couple wraps of electrical tape
Just kidding.
McSteve is offline   Reply With Quote
Old 12-29-2011, 09:21 PM   #12
biggles's Avatar
if they have a load on them and they don't twist with the nut could arch and melt the wire nut..seen it anything more the 3 wires quick twist then use the "bullnose"... turning the wire nut
Old 12-30-2011, 02:36 AM   #13
Julius793's Avatar
Always pre twist
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Identify age of old Romex - also funny ground Leah Frances Electrical 9 02-06-2012 12:07 AM
How to build a romex spinner jimmy21 Electrical 17 02-06-2012 12:01 AM
Fishing Romex through walls Tetranitrate Electrical 6 07-09-2011 06:12 AM
romex clamped against bx knockout in old box kbm774 Electrical 11 08-16-2010 01:53 PM
Connecting Romex at Panel Bocolo Electrical 14 02-21-2009 05:55 AM
