Twist Wires For Wire Nuts Or Not? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-19-2011, 05:16 PM   #1
Rewards Points: 262
Twist wires for wire nuts or not?
Setting up my wiring for a kitchen renovation, setting up grounds and pigtails. A friend of mine said that you don't have to twist the wires for a wire nut, but the person I learned from twisted the wires and wrapped the wire nut connection with elec tape. Is the twisting of the wire ends overkill, or will an inspector look for that detail? Thanks.
tpagel is offline   Reply With Quote
Old 06-19-2011, 05:19 PM   #2
Learning by Doing
Leah Frances's Avatar
Seems to be personal preference to some extent. Not twisting doesn't seem to be enough of a time saver to justify the chance the nut could fail/slip/whatever.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 06-19-2011, 05:31 PM   #3
Just call me Andrew
Rewards Points: 1,020
There have been MANY threads discussing both pre-twisting the wires and the use of tape.
Twisiting of wires: Under normal circumstances it is unnecessary if you properly fasten the wirenut.
Electrical tape: completely unnecessary and amateurish
Andrew
secutanudu is offline   Reply With Quote
Old 06-19-2011, 05:31 PM   #4
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Twisting the wires is not required although I prefer it. Tape is not needed either.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 06-19-2011, 05:40 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,972
Two bottom lines:
- The wires should look the same whether you pre-twist or not. Meaning, you MUST twist the wire nut enough to twist all the conductors together.
That said, pre-twisting is a for-sure way of getting it right.
- On a properly installed wire nut tape is unnecessary, amateurish and messy. If you think tape helps, think again.
Old 06-19-2011, 05:40 PM   #6
biggles's Avatar
advantage is they disconnect when un nutted but if there is a load they will spark..twisting them aces that problem but need to recut when you renut them....this on solid wire more the stranded but it is an electricans install choice
Old 06-19-2011, 05:45 PM   #7
If you twist them its better and the wire nut will not fail and if you twist them you do not have to cut them if you wish to redo something you just untwist them
jmans8666 is offline   Reply With Quote
Old 06-19-2011, 05:46 PM   #8
See post #5.
Also, WHY are you removing a wire nut on an energized circuit?????
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
jamiedolan (06-19-2011), Leah Frances (06-19-2011)
Old 06-19-2011, 08:43 PM   #9
Learning by Doing
Yes, nuts alone are fine. But, I too don't really trust myself unless I pre-twist.
Also, taping over wire nuts is bad karma.
Old 06-19-2011, 09:13 PM   #10
electures's Avatar
Taping wirenuts is a sign of an amature.
Old 06-19-2011, 10:04 PM   #11
Rewards Points: 262
Thank you for all the replies. I appreciate the insights.
Old 06-20-2011, 05:57 AM   #12
Rewards Points: 1,666
Or use these and not have to worry about taping and twisting:
http://www.idealindustries.com/media...um/in-sure.jpg
bob22 is offline   Reply With Quote
Old 06-20-2011, 06:44 AM   #13
Rewards Points: 1,536
For three or more wires, in order for a twist to be secure the bare wire ends have to be so long that bare wire protrudes from the wire nut. Then I need tape to cover it.
Old 06-20-2011, 07:07 AM   #14
Rewards Points: 756
Then you're not twisting them correctly.
busman is offline   Reply With Quote
The Following 4 Users Say Thank You to busman For This Useful Post:
electures (06-20-2011), HouseHelper (06-20-2011), Leah Frances (06-20-2011), Speedy Petey (06-20-2011)
Old 06-20-2011, 08:32 AM   #15
Learning by Doing
He may be twisting them correctly, but not trimming the twist afterwards for proper length.
Exposed copper after the wire nut is on is a big NO NO.
Wrapping electrical tape around it is not a solution for that problem.
Ceiling Fan installation, 3 sets of wires in ceiling southnam Electrical 3 09-13-2010 03:00 PM
Adding additional outlet. Pigtail four sets of wires? svanhess Electrical 5 07-12-2009 10:27 PM
installing an electrical outlet with 3 sets of wires + ground dsparks Electrical 7 07-08-2009 06:18 PM
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 06:01 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
