Twist Wires Together Before Installing Wire Nut? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-21-2011, 09:46 AM   #1
Twist wires together before installing wire nut?
I just watched a very good video showing how to install a transfer switch.
http://www.reliancecontrols.com/Stre...r_DSL.aspx
When he connects a pair of wires, he does NOT twist the 2 wires together before installing the wire nut. I thought the wires should always be twisted together first - am I wrong?
Bill
bw777 is offline   Reply With Quote
Old 01-21-2011, 10:16 AM   #2
joed's Avatar
Rewards Points: 12,904
It is a person choice. It is not required by any code. I don't usually do it.
Old 01-21-2011, 10:36 AM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 488
Like joed said, personal choice.
I pretwist. That was the way I was taught, that's how I done it all these years.
Old 01-21-2011, 10:37 AM   #4
What I do to check the tap is pull each wire to make sure they don't pull out from the wire nut. Also, if the wirenut is installed properly there will be no way that you can pull the wire nut off the wires.
AndyinAtl is offline   Reply With Quote
Old 01-21-2011, 12:15 PM   #5
Rewards Points: 1,514
The wire is held in the wire nut because:
1. It is pretwisted so the other wires help lock it in place,
2. The spring in the wire nut bites into the wire.
When there are more than four wires in the wire nut and not pretwisted there is a chance that one wire will be in the middle and not bitten into by the spring.
But pretwisting the wires enough so they hold together by themselves requires so much bare wire that the wire nut won't cover it all.
Old 01-21-2011, 01:50 PM   #6
And Still Learning
No twist here. Just tighten the He!! out of them. If there is any chance of moisture getting inside the wire nut I make sure it is pointed up. If there is any chance that anyone except me going back into the job I will wrap the nut with black tape, such as at work.
Know It ALL is offline   Reply With Quote
Old 01-21-2011, 03:29 PM   #7
Licensed electrician
Rewards Points: 1,622
As others have said, this is a personal preference.
You only need about 3/4" of bare conductor if you are going to pre-twist 4-5 conductors. This can also be trimmed. There is no reason a wire nut would not cover this amount of bare conductor.
Old 01-21-2011, 04:16 PM   #8
WaldenL's Avatar
Rewards Points: 268
For 2 or three I don't pretwist. 4+ I tend to, but that has less to do with ensuring a connection and more about wire length. With the twist I don't need them to all line up at the top, instead I twist them, not caring if a couple are longer, and then cut the bundle so they all end at the same point.
WaldenL is offline   Reply With Quote
Old 01-21-2011, 05:29 PM   #9
joed's Avatar
There is only one time I actually pretwist. When installing replacement ballasts in Fluorescent lights. I pretwist the two line wires together and then add the ballast wire to the group. This makes it easier neat time to replace the ballast. The ballast wire comes out easy and the power wires stay together.
Old 01-21-2011, 06:04 PM   #10
Bigplanz's Avatar
Rewards Points: 990
I haven't used a wire nut in a couple of years. I prefer push connectors. Easy to install, easy to check for correct installation (clear end of the connector shows the wire) and they work fine. They are code compliant as well.
Bigplanz is offline   Reply With Quote
The Following User Says Thank You to Bigplanz For This Useful Post:
MichaelWSmith (04-10-2011)
Old 01-21-2011, 06:16 PM   #11
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
not again
If you install the nuts properly, the wires will become twisted. Therefore, no need to pre-twist. There are times when gathering a large quantity of wires to nut together, pre-twisting helps keep everything together when you try to nut them.
Old 07-14-2013, 10:59 AM   #12
twisting nicks the wires?
When twisting wires with dikes doesn't the teeth on the dikes cut into the wires and create hot spots? Or do you strip further back, twist, then cut off the damaged part from twisting? I was told to be very careful not to nick or damage the wires. When twisting 4 or more wires the insulation is stripped back further, twisted, and then cut down to length to fit the wire nut thus the damaged part is removed. Is this correct? Just curious if that's how everyone else does it. 2 or 3 wires I just twist them into the nut really tight.
Toothless is offline   Reply With Quote
ROMEX 14-2 wire from Canada Vs. ROMEX 14-2 wire from the U.S. Dazzlin Electrical 18 11-02-2016 03:15 PM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 04:02 PM
installing an electrical outlet with 3 sets of wires + ground dsparks Electrical 7 07-08-2009 06:18 PM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 01:00 PM
installing a subpanel from 10/2 wire. d_skutnik Electrical 7 10-08-2008 05:35 PM
