Twist Lock Plug Is Stuck! - Electrical - DIY Chatroom Home Improvement Forum
Old 03-07-2010, 05:39 AM   #1
Rewards Points: 150
Twist lock plug is stuck!
I am installing a new pool pump - but the old one doesn't want to let go. It's a twist lock plug (I think)...it won't come out. I tried turning and pulling both directions...I am a bit embarrassed that I can't figure this one out. It's been installed for six years - could it be fused to the outlet?
joemontana16 is offline   Reply With Quote
Old 03-07-2010, 06:08 AM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Very well could be. May be the reason why the old pump didn't work.
wirenut1110 is offline   Reply With Quote
Old 03-07-2010, 08:06 AM   #3
Rewards Points: 1,506
Does the plug still twist? (maximum is about a quarter inch)
If not then you are stuck (no pun intended).
With the plug twisted all the way to the left you can try inserting a screwdriver between the plug and the receptacle and prying it loose. Insert the screwdriver and pry just a little in different places all around, don't just insert it once and pry.
Old 03-07-2010, 11:56 AM   #4
Mad Scientist
This might be obvious, but worth mentioning. If you try prying with a screwdriver, PLEASE make sure the power is off to the receptacle first.
-McSteve
McSteve is offline   Reply With Quote
Old 03-07-2010, 05:25 PM   #5
DIYer
Are you sure it's a plug and not the end fitting of liquitight conduit?
Some of those kind of look like plugs...
http://www.crouse-hinds.com/crousehi...iquidtight.jpg
Post a picture if you can.
Gigs is offline   Reply With Quote
30A 240v plug Red Squirrel Electrical 3 07-22-2009 12:48 AM
Unpolarised US Type 2 Plug to UK Plug. razorcut Electrical 19 05-18-2009 09:49 AM
foot lock drain plug..how to re-assemble? firsthomenewb Plumbing 1 03-01-2009 12:53 PM
20 amp plug MikeyP Electrical 6 01-03-2009 09:04 PM
New plug for toaster oven? mike720 Electrical 3 11-23-2008 07:44 PM
