Twin & Earth Core Joining - Electrical - DIY Chatroom Home Improvement Forum
Old 08-29-2012, 06:45 AM   #1
Hi,
I have 0.75mm Sq T&E coming to a Halogen Light. I now want to move the Halogen Light to another location about 6 mtrs away. I have 1.0mm sq T&E available to use. Can I join 0.75mm sq T&E to 1.0mm sq T&E?
ampalert is offline   Reply With Quote
Old 08-29-2012, 07:59 AM   #2
Master Electrician
Yes as long as its fused or breaker protected at the .75mm appropriate size.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
The Following User Says Thank You to andrew79 For This Useful Post:
ampalert (08-29-2012)
Old 08-29-2012, 09:21 AM   #3
Thanks Andrew
Yes it is connected to a fused spur. Just wanted to check that the power going to the 400w light would not be affected if the cable size changed from .75mm sq to 1.0mm sq
Question: Can I Install Pergo over Dri Core? Starlight Flooring 1 10-01-2010 08:05 PM
Joining Several Hollow Core Doors JustPamela Carpentry 14 03-04-2010 10:13 AM
Polish flat - No earth! Sosh Electrical 3 07-10-2007 11:49 AM
3 phase anyone? Tomkah Electrical 3 01-05-2007 05:18 PM
