Twin Breakers - Electrical - DIY Chatroom Home Improvement Forum
Old 09-21-2010, 08:18 PM   #1
Twin breakers
I have a Bryant electrical panel (100 Amps)that has space for 20 circuits. It is 35 years old but it is a CTL class box.. I need to add two additional circuits for a radon fan and a sump pump. I purchased Cultler Hammer BR1515 breakers (which are non-CTL). They will replace two regular Bryant breakers adding the extra place for the two circuits. I was told Cutler now owns Bryant and is the proper replacement.
When I tried to install the tandem breaker in the box, it didn't seem to fit and I did not want to force it. My questions are:
Should this breaker fit in the box?
How can I tell if this box accepts tandem breakers as the diagram and label do not indicate which slots would accept this type of breaker?
If I can't use tandem breakers, can I put two wires in a Bryant breaker, assuming I do not exceed amperage loads?
John
jds2480 is offline   Reply With Quote
Old 09-21-2010, 09:06 PM   #2
Electrical Contractor
kbsparky's Avatar
Make sure you didn't get a type BD1515 by mistake. I've seen the breakers in the wrong bins at the local home-horror stores on several occasions.
The BR type should fit on the buss bar without any problems. The type BD needs a notch in the buss in order to properly fit.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
jds2480 (09-22-2010)
Old 09-22-2010, 07:57 AM   #3
Licensed electrician
Rewards Points: 1,622
Non-CTl breaker should not be used in a CTL panel. They are not listed for use in that panel and installing them puts you over the number of breakers allowed in that panel.
Old 09-22-2010, 06:01 PM   #4
Twin Breakers
The new breakers are definitely BR1515 so I will try again to fit them in the panel. I am not worried about overloading the panel as it is only me and my wife in the house and we are not heavy users of electricity.
Is this a better option than putting two wires in one of the current breakers?
Can I get AFCI breakers for my panel? BlueBSH Electrical 21 08-04-2010 07:07 AM
Total of Circuit Breakers xraydido Electrical 19 05-13-2010 01:08 PM
Can I install tandem breakers to stop my breakers from tripping? sofakng Electrical 1 04-29-2009 01:44 PM
Help! Circuit breakers in trouble Circuit breakers Electrical 9 12-22-2008 12:58 PM
Trying to find twin breakers to fit panel taybrynn Electrical 11 10-28-2008 10:24 AM
