Tv Wall Mounted Wiring? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-15-2011, 07:33 PM   #1
Tv wall mounted wiring?
I have mounted my television on my bedroom wall. The wall that it is mounted on happens to be on an exterior wall. I would like to run the wires behind the wall, however, I am worried that I am goiing to get a draft thru the opening where the wires will be ran. Does anyone make a certain electrical box cover that I will be able to feed my tv power wire and hdmi cable thru so it that it also will not allow a draft thru? Open to any suggestions!
cklesta is offline   Reply With Quote
Old 03-15-2011, 07:46 PM   #2
You can not, I repeat can not, run the tv cord down the inside of the wall and plug into an outlet. You must install an outlet up near the tv. As far as the draft...you can use foam insulating spray
heartlessmcfly is offline   Reply With Quote
Old 03-15-2011, 09:53 PM   #3
Cut a dual gang box into the wall somewhere hidden behind the TV, and add a decora wall plate. One gang can have keystone inserts for coax (or HDMI or whatever), and the other gang can house a duplex power outlet. Then the TV can simply plug in directly to the wall behind it. Run the wires straight down (or wherever) to the cable box area for the mating coax/hdmi, and tie into an existing outlet. Shove a bunch of extra insulation around the box, or spray foam around it to seal it off.
http://www.amazon.com/Arlington-DVFR...0243781&sr=1-3
http://www.amazon.com/Decora-Type-Ke...sr=1-2-catcorr
http://www.amazon.com/Keystone-Coaxi...sr=1-2-catcorr
http://www.amazon.com/Keystone-Coupl...0243879&sr=1-2
http://www.amazon.com/Leviton-T5325-...0243911&sr=1-1
Mikef5000 is offline   Reply With Quote
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 06:23 PM
How to get wiring into wall with tongue and groove panels npn_ Electrical 4 03-05-2011 04:52 PM
Wall mounted clear perspex noticeboard AuldKinman Interior Decorating 0 07-17-2010 09:45 PM
GFCI for wall mounted aquarium LOST VEGAS Electrical 4 04-19-2010 06:58 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
