TV Power Cord Extention Requirement - Electrical - DIY Chatroom Home Improvement Forum
Old 09-07-2010, 07:33 PM   #1
TV power cord extention requirement
I just purchased and hung a new samsung flat screen tv. The power cord does not reach the nearest outlet. The power cord is labeled 10A 125V.
I need to know what extention cord size is safe to use. Any help will be appreciated.
cece is offline   Reply With Quote
Old 09-07-2010, 07:35 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
do you want an answer that works or one that is legal?
legally, extension cords are not to be used for permanent installations.
what will work is just about any extension cord. Most are rated for at least 15 amps. Check on the packaging.
Old 09-07-2010, 07:46 PM   #3
Is it possible for you to install a new outlet from below or above
macdonald is offline   Reply With Quote
Old 09-07-2010, 08:06 PM   #4
Licensed electrician
Rewards Points: 1,876
Installing a new receptacle would be my choice.
Old 09-07-2010, 08:10 PM   #5
I=E/R
a7ecorsair's Avatar
But legally he could cut the plug and solder on an extension, heat shrink the two wires, and then heat shrink over the complete splice.
a7ecorsair is offline   Reply With Quote
Old 09-07-2010, 08:24 PM   #6
Doing so would remove the UL listing from the television.
I would not advise this to be done.
Old 09-07-2010, 08:31 PM   #7
I=E/R
a7ecorsair's Avatar
So technically, when the cord or plug goes bad on my wife's $300 mixer, the mixer has to be thrown away.
Old 09-07-2010, 08:33 PM   #8
nap
You talking to me?
nap's Avatar
No, the cord should be replaced with a proper cord, not some cobbled up Frankencord.
Plugs can be replaced because the plug can be replaced with a UL listed replacement plug.
The Following User Says Thank You to nap For This Useful Post:
Jim Port (09-07-2010)
Old 09-07-2010, 08:36 PM   #9
Legally ?
I can't recall ever seeing an extension cord marked for Temp use only
If its the law shouldn't they be marked that way ?
I've been living here 7 years & I have either surge protectors or extension cords plugged into every outlet I use
Lamps etc used to always have 6' power cords
Now they are just short enough to make the 6' rule "obsolete"
While its in the NEC (90 day temp use - geared towards Holiday lighting ?) I think its something that they can't possibly regulate
Of course I unplug mine every 89 days to stay legal
Old 09-07-2010, 08:42 PM   #10
nap
You talking to me?
nap's Avatar
Originally Posted by Scuba_Dave View Post
Legally ?
While its in the NEC (90 day temp use) I think its something that they can't possibly regulate
the NEC doesn't regulate anything. It is simply a book full of suggested rules.
Old 09-07-2010, 08:44 PM   #11
Just call me Andrew
Rewards Points: 1,020
It's certainly full of something!
Andrew
secutanudu is offline   Reply With Quote
Old 09-07-2010, 08:53 PM   #12
Interesting...looking into this it appears that surge protectors are not the same as extension cords
So those are Ok....
I have mostly surges in use....but a few extension cords
My comment RE "legally".....
Is if its "illegal" to use them for periods beyond 90 days then its a law
not a suggested rule...
Old 09-07-2010, 08:54 PM   #13
No, you would replace the damaged part with an approved replacement part.
Old 09-07-2010, 09:43 PM   #14
nap
You talking to me?
nap's Avatar
my point was that the NEC does not require anything. The building department, fire department, AHJ's, whatever require things. They generally require what is listed in the NEC but the NEC itself does not require anything.
It is when those with the authority require you to follow the suggestions in the NEC they become law.
so, it's not the NEC that regulates but the AHJ and the AHJ that makes the suggestion into law.
semantics.
but yes, there are rules that, when enforced by those with the authority, do not allow the use of extension cords for a permanent installation. As you stated, surge suppressors or even power strips are allowed. Extension cords can easily become fire hazards when they are installed in a manner they are walked over or run over with anything.
Old 09-08-2010, 07:56 AM   #15
Rewards Points: 6,652
How much longer are we talking here? You can get a longer cord from http://www.monoprice.com/products/su...02&cp_id=10228. Do not go too long, or else the set may not work properly.
How do I get power to a new ceiling fan? sestivers Electrical 15 10-10-2016 04:16 PM
Ele hot water tank and welder sharing circuit wazeaz Electrical 68 03-19-2008 07:17 PM
need instructions on replacing a Whirlpool refrigerator power cord please. ChrisC30 Electrical 2 03-10-2008 09:59 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
