Turning Switch Off Trips Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 02-08-2011, 09:21 AM   #1
turning switch off trips breaker
so i was adding a few recessed lights onto an already existing circuit which is run off of a three way switch circuit. all of the wires that run to the lights in the basement run through the box that i tapped off of. i then disconnected the previous connection, added my hot lead and reformed the connection. then i did the same with the neutral. lights came back on. then when leaving the basement i went to turn the lights off and the breaker tripped. i cannot figure how running power through the circuit does not cause the breaker to trip, but when i turn the power off, it trips. if anyone has insight on this i would appreciate it
nhep is offline   Reply With Quote
Old 02-08-2011, 10:05 AM   #2
joed's Avatar
Rewards Points: 13,306
Tell us exactly everything you did. Did you find a white connected to a black and "FIX" it by connecting to the other whites?
I am betting you are actually turning ON the switch when the breaker trips.
Old 02-08-2011, 02:36 PM   #3
You mentioned three-way switches.... I'm betting that you have a traveller connected to neutral or shorting to ground.... when the other traveller is active, there is no fault, but when either switch is reversed, then you get a trip.
Start by rechecking all connections at both switches.
clashley is offline   Reply With Quote
Tags
breaker , three way switch , tripping
Tripped breaker installing new light switch? tylermac Electrical 3 02-05-2011 04:57 PM
B&S Generator with Connecticut Electric Xfer Switch Rick5150 Electrical 19 01-20-2011 10:14 PM
single-pole switch trips breaker Annapolis, MD Electrical 8 02-26-2010 11:32 AM
What did i do wrong? - Outlet install trips breaker nymex Electrical 22 05-07-2009 02:44 PM
Switch trips Breaker pvrio Electrical 4 09-21-2008 04:53 PM
