Turning OFF Light Switch Causes AM Radio Interference ? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-18-2011, 11:05 PM   #1
Turning OFF light switch causes AM radio interference ?
AM/FM clock radio plugged into wall outlet gets heavy interference on the AM radio band if the light switch in the next room is turned OFF. No inteference when switch is ON. Two different 110v circuits involved. Switch controls a ceiling light/fan combo.
Any ideas? Thanks.
Grant
gcmackinnon is offline   Reply With Quote
Old 10-18-2011, 11:11 PM   #2
liscenced electrician
Rewards Points: 538
sounds like you just seem to be getting better reception when there is power in the wire. I can't tell you what causes this (youd need to talk to a scientist) but i can tell you im 99% sure there isn't any real issue. Perhaps you could label the switch with the word "antenna"
jimmy21 is offline   Reply With Quote
Old 10-18-2011, 11:13 PM   #3
Rewards Points: 6,652
Been like that since the dawn of time with AM radios.
Old 10-19-2011, 09:13 AM   #4
joed's Avatar
Rewards Points: 13,742
Is the switch lighted? What type of lamps in the fan?
Old 10-19-2011, 12:03 PM   #5
Semi-Pro Electro-Geek
Rewards Points: 2,990
Is the switch a dimmer, fan speed control, wireless fan control, lighted switch, or anything else other than just a totally basic plain switch? If so, the culprit is the electronics in the switch. If not, then we'll have to keep hunting...
mpoulton is offline   Reply With Quote
Ceiling Fan and Light Switch Problem desiboy Electrical 3 03-03-2011 12:09 PM
HELP.. trouble adding light to single pole switch RickDel Electrical 13 09-09-2009 10:18 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 09:02 AM
no power going to the light switch baseballfan Electrical 18 09-08-2008 05:35 PM
