Turning Off The GFCI Safe Enough To Work Downstream? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-12-2010, 06:22 PM   #1
Rewards Points: 278
turning off the GFCI safe enough to work downstream?
I need to tap in an outlet downstream of a GFCI, if we press the test to trip the GFCI, all downstream outlets are off, beside the fact someone else could press the reset button on the GFCI and hurt me, is it safe to work on, because there is refrigerator upstream and I am considering not turning off the breaker.
DIYGST is offline   Reply With Quote
Old 02-12-2010, 06:26 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 552
Don't take a chance, turn of the breaker and put the fridge on a cord until you finish.
Old 02-12-2010, 06:32 PM   #3
Licensed electrician
Rewards Points: 1,766
A refrigerator will stay cold enough for several hours with the power off. The less the door is opened the longer the time will be. Turn the breaker off.
Old 02-12-2010, 06:33 PM   #4
I'd turn the breaker off too...even if I'm the only one home
Old 02-12-2010, 06:35 PM   #5
Rewards Points: 278
Thanks, just trying to understand what the CGFI is switching though, for purely educational purpose
Old 02-12-2010, 07:24 PM   #6
Idiot Emeritus
Rewards Points: 1,492
A properly connected GFI will open both the hot and neutral when it trips.
In theory, it's completely safe to work on something downstream of a GFI if it's tripped, and if the downstream device is actually fed from the load side of the GFI.
Would I do it? I work a lot of stuff hot, and have done so for the past 20 years. If the downstream device is something I'd consider working hot anyway, then yes. But I'd work it like it was actually hot.
Standing in a foot of water? Absolutely not! I'd kill the breaker, and lock it out. Even if I was the only one around.
I would consider tripping a GFI to give me a slight edge on safety, but there's no way I'd depend on a tripped GFI if it was the only thing between me and death.
Rob
micromind is offline   Reply With Quote
GFCI Breaker & GFCI Outlet together??? abinpa General DIY Discussions 6 04-12-2009 08:59 PM
GFCI receptacle gets tripped by hallway light proofer Electrical 10 03-17-2008 07:29 PM
Hiring guys to do work without a contractor Safe or Not Worth Liability wise? twilightcall General DIY Discussions 1 03-15-2008 08:40 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
GFCI protection for Shop/Garage Sub-Panel porterpearl Electrical 3 01-06-2006 03:33 PM
