Old 05-22-2007, 11:06 PM   #1
Question
Turning main power supply off from the meter
i feel uncomfortable working with my breaker box while the feeder cable is hot (even when the box is turned off). i was thinking that i could just turn off the main supply from the meter but i could not find a way to do it. attached is a pic of the meter. the house is almost 100 yrs old, so i guess the meter is not the latest model either.
please help. i need to replace some breakers.
thanks,
- a
Old 05-22-2007, 11:28 PM   #2
You may not under any circumstances do any work concerning that meter socket. If you ask, the utility company will come out and disconnect it for you..
They may require an electrical inspector come out and call them before they turn it back on.
The reason why working in a main panel is not safe is because the next disconnect is a cut out from the utility that may feed several homes.
If you are not comfortable doing this, then by all means hire it done, by a licencenced professional.
Master Electrician
jwhite is offline   Reply With Quote
Old 05-22-2007, 11:33 PM   #3
I once read an article in the utility companys safety sheet about a meter man who was in critical condition from not installing an electrical meter correctly. The meter blasted off the house with enough force to leave glass shards throughtout his body.
If you do not have the proper equiptment and training, do not remove or install an electrical meter.
Master Electrician
turning gas on/off at the meter amakarevic Plumbing 17 04-23-2011 08:21 PM
test new power supply? darsunt PC Repairs & Upgrades 8 09-08-2007 08:04 PM
Main Breaker Trips Repeatedly kkf Electrical 7 06-18-2007 05:31 PM
Need a new power supply Alan PC Repairs & Upgrades 18 06-15-2007 01:57 AM
Turning valve at water meter KCnorthernCA Plumbing 15 10-23-2006 12:35 AM
