Turn Off All Breakers Including Main And Light Stays On - Electrical - DIY Chatroom Home Improvement Forum
Old 10-16-2012, 07:58 AM   #1
danielb's Avatar
turn off all breakers including main and light stays on
Hello, I have been having this problem when I turn off all the breakers including the main the lights stay on in my upstairs, please someone help! Thank you!
danielb is offline   Reply With Quote
Old 10-16-2012, 08:02 AM   #2
Rewards Points: 14,312
Then there's another panel someplace.
It's common to have two panels when there's two floors in a home.
Old 10-16-2012, 08:05 AM   #3
danielb's Avatar
Okay, I would imagine it is in my attic then because I have been searching for another panel for a couple of days now. Thank you for the quick reply
Old 10-16-2012, 08:33 AM   #4
Not likly it's in the attic. Checked the outside walls near where the meter base is?
Old 10-16-2012, 09:19 AM   #5
Electrical Contractor
kbsparky's Avatar
Some older houses have panels in the attic.
Don't rule them out without at least looking up there ...
-KB
Old 10-16-2012, 09:33 AM   #6
danielb's Avatar
Okay never thought about outside by the meter, and I was just assuming the attic but you know when someone starts assuming haha! Thanks alot everyone I appreciate it.
Old 10-16-2012, 10:02 AM   #7
Rewards Points: 1,488
Could be like my house with the old Zinsco panel.
All 220v, and some 120v, are outside in a meter base panel, and then there's 120v sub panels in the garage, crawl space, and attic.
A total PIA. Especially so for setting up a transfer switch for the generator.
ktkelly is offline   Reply With Quote
Old 10-16-2012, 10:15 AM   #8
danielb's Avatar
Well the panel in the basement is new when I moved in 3 yrs ago and never had to do anything with the upstairs lights until I was told to put a ceiling fan in the master bed room.
Old 10-16-2012, 10:32 AM   #9
Rewards Points: 38
is this a single family house or multi unit? If multi unit it would be a possible case of "mixed" wiring. If this was a multi and converted to single unit, you may have more than one main panel as already mentioned.
bernie
bernie963 is offline   Reply With Quote
Old 10-16-2012, 10:37 AM   #10
danielb's Avatar
Its a 3 story house basement, living room dinning room, kitchen area living courters and upstairs is all the 3 bed rooms.
Old 10-16-2012, 10:45 AM   #11
Rewards Points: 1,300
Is the panel box marked as to what each breaker controls? Also, if you can, post a picture of the box with the door open and all the wires coming out of it. We may be able to see if there is a sub panel wire coming out from it. My first suspicion is a sub panel somewhere and my next is the main is not actually turning off along with the breaker for the lights.
danpik is offline   Reply With Quote
Old 10-16-2012, 10:48 AM   #12
danielb's Avatar
I can post a picture later today after I get off work and no to my convience they didn't list what each breaker shuts off which is really easy to work with lol not.
Old 10-16-2012, 05:08 PM   #13
joed's Avatar
Rewards Points: 13,762
Post a picture of the meter as well.
Old 10-16-2012, 07:01 PM   #14
danielb's Avatar
Hello all, turns out i am an idiot and it was right under the meter lol. There was another breaker box which of course had the upstairs light breaker. Thank you for everyone that helped couldn't ask for better people!
How to isolate outlets from main light switch? jtrom Electrical 7 10-10-2012 09:35 AM
Wiring a Shed light & internal power DJDesq Electrical 4 08-12-2012 08:12 PM
main burner goes out after furnace running 10 -2 0 mins marion60 HVAC 4 11-02-2011 09:53 AM
Heatilator ND4236i - main will not light flew-d-coop HVAC 4 12-13-2010 05:34 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
