Old 01-24-2008, 05:17 AM   #1
turn main panel into a sub panel?
I need to add a new panel in my garage since I will be turning it into a workshop. I'm not sure on the best way to set it up.
Here is the situation:
Service comes in from an underground conduit to the meter in the garage. Then is goes to a small box with the main breaker (2 100amp breakers) From there it goes into another conduit and goes down to the basement to the breaker panel. Since I need to add several circuits in the garage, the best place for a new panel would be in the garage. I was thinking i could add the new panel and have it feed from the main breaker, then feed the existing panel off of the new one, therefore turning it into a sub panel. One problem I see with this option is the existing panel has a high load on it.(220v water heater, dryer , range, plus all other 120v circuits) I think there is a limit to the load a sub panel can have. Is that correct.
The other option would be to run a line from the existing panel back up to the garage and just install a sub panel there. That just seems a little silly since the power comes into the garage.Kind-of like running an extension cord down the hall to another room when you have an outlet right next to you.
tikicarver is offline   Reply With Quote
Old 01-24-2008, 07:07 AM   #2
waiting for spring
arichard21's Avatar
If you do run your existing panel as a sub, remember that the neutrals and grounds have to be seperate and the bonding strap between the 2 bars will have to be removed.
arichard21 is offline   Reply With Quote
Old 01-24-2008, 08:37 AM   #3
Licensed Pro
If your main panel is fed from a main breaker next to the meter, then it should already be wired as a subpanel. It may be possible to replace this disconnect at the meter with a larger main service panel to feed the garage and the house panel.
HouseHelper is online now   Reply With Quote
More On This Topic
Hi! My name is Adolph Ramirez from Tampa, Florida. On behalf of Expert Village, this is how to install a ceiling fan. The number one thing to think when you are messing with electricity is safety, safety, safety. You don't want to get electrically... Read More »
Let's talk about putting a sign on the breaker box to warn others to avoid others turning our breaker back on. You can say something on your sign similar to what I have. Do not turn circuit breaker number 15 on. Bill is installing a dimmer switch in the... Read More »
Hi! My name is Chad Smith and I'm a state certified Journeyman Wireman basically a electrician and I'm representing expertvillage.com. Today we are installing a new doorbell in our house here. The first step that you should take when you are installing... Read More »
Hi! I'm Chad Smith and I'm a State Certified Journeyman wireman. Basically, I'm an electrician. I'm here with expertvillage.com today. The first step that you are going to want to take when you are doing anything with electrical work is you are going to... Read More »
Before removing the existing switch, you must first turn off the electrical power to the circuit involved. If you are really lucky, the circuits will be marked accurately. Most likely though you will have to turn a few breakers on and off until you find... Read More »
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 10:40 AM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 09:18 PM
Main panel design question amakarevic Electrical 13 06-04-2007 05:35 AM
Arced main lug in service panel burgeke Electrical 4 11-02-2006 12:28 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
