Trying To Understand 240v Wire Selection - Electrical - DIY Chatroom Home Improvement Forum
Old 05-24-2009, 08:21 AM   #1
Trying to Understand 240v wire selection
Hey Folks,
Concerning installing 240v power I've noticed sometimes its required to have a 3 wire/wgrnd and other times it seems only a 2 wire/wgrnd is required. Can someone explain when and why there are sometimes different requirements? Is it an Amp related reason?
It helps when I can understand the concept/reasoning.
Bama is offline   Reply With Quote
Old 05-24-2009, 08:36 AM   #2
Rewards Points: 2,350
Originally Posted by Bama View Post
Hey Folks,
It is a voltage question. 240 V equipment needs two wires and a ground. But 120/240 V equipment needs three wires and ground. Your electric clothes dryer, for instance is NOT a 240 V appliance. It is 120/240 V. The dual voltage rating means that the appliance itself has some internal equipment that use 120 V, and other parts that use 240 V. A neutral is needed in this case to supply the 120 V loads.
Wire size, on the other hand, is determined by amps. An amp is an amp, no matter what voltage.
Old 05-24-2009, 08:38 AM   #3
Bigplanz's Avatar
Rewards Points: 990
Hey Folks,
Two hots and a neutral are needed for a 120/240 circuit, like a dryer. Part of the dryer runs on 120, while the heating element requires 240. The neutral allows for a return path for the 120V portion of the circuit. A 'straight' 240V circuit requires two hots and a ground. The two hots complete the 240V circuit, no neutral is required. The ground is required for both, of course.
Bigplanz is offline   Reply With Quote
Old 05-24-2009, 09:36 AM   #4
Thanks. I understand now. I appreciate you taking the time.
New Stove, old wires - 2 wire vs 3 wire DIYGST Electrical 22 03-02-2009 04:13 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 01:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 09:00 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
