Trying To Run 220machines To My Grage What Wire? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-01-2012, 06:21 PM   #16
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
Originally Posted by flasherz View Post
No, you're suffering from "I have to be right" syndrome.
And you are suffering from saying one thing, meaning another, and not being sure of either.
The OP asked if he could use only 2 conductors and a ground rod, which presumes the grounded and grounding conductors would be pathed through the earth. That, as you and I both agree is a big, big no-no.
I explained that he could not and must run 4 conductors, which is correct and code-compliant. Knowing that the question of grounding rods is asked frequently by posters because of the formerly code-compliant method, I explained he could not use a single conductor for the grounding and grounded conductors, bonded together in the panel and connected to grounding electrodes -- which is what I described and is, indeed, formerly code compliant.
That is NOT what you said previously.
You are trying to argue that I suggested the grounded conductor could be serviced with a ground electrode only, which I never said and would never say.
No, but you suggested that the ground rods were in lieu of an equipment ground.
I believe you meant "you're welcome". HTH.
Yup, you're right.
Wow. You caught my one in a thousand typo. You must be SO proud, especially after your attempted stealthy quasi-intelligent insult from earlier.
Whatever. This is no fun any more so I am done. Reply back if you like, but I won't bother any more.
Old 11-01-2012, 06:25 PM   #17
Common Sense Common Guy
Rewards Points: 161
That is indeed what I said, it's still all in the post -- read it. You're finding yourself still having to be right about it because you read what I typed and assumed I said something I didn't.
It never was fun for me, I didn't view electricity as a game. I gave straightforward, truthful advice to the OP and you decided to attack me. Likewise, I'm finished with this.
flasherz is offline   Reply With Quote
Old 11-02-2012, 04:40 AM   #18
Thanks guys for a great argument! It realy helped me out and see why its not code that way.anyway i think ill begoing with thw 4-4-4-4 direct burial for both runs...i found some for 190$ for 100ft... thanks for your help !!
Zepplin1 is offline   Reply With Quote
THWN wire; Gray pvc Conduit; and GFCI receptacles Buzzy Electrical 29 09-26-2012 02:41 AM
ceiling fan wicked97 Electrical 4 08-21-2011 08:12 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 01:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
