Trying To Prove A Point - Electrical - DIY Chatroom Home Improvement Forum
Old 12-12-2011, 02:17 PM   #1
Rewards Points: 150
Trying to prove a point
Hey guys!! Hope all is well. Me and my coworker came across a small disagreement and I'm trying to prove him wrong so I need a little help. I'm trying to explain to him that there is no " Written Law" on using high voltage colors (brown, orange, yellow) when running wires for high voltage lighting. We all do it as electricians, but it isn't law. Any feedback would be greatly appreciated. Thanks guys
Sunny B. is offline   Reply With Quote
Old 12-12-2011, 02:44 PM   #2
My understanding is indirectly, from this forum and others. I understand the NEC DOES specify certain colors: green is ground, white is neutral (grounded conductor). All other colors are unspecified, but assumed to be "hot". Whether it is "law" is dependent on one's local jurisdiction.
oberkc is offline   Reply With Quote
Old 12-12-2011, 03:02 PM   #3
Rewards Points: 150
Thanks!!! And I believe grey is also specified.
Old 12-12-2011, 04:10 PM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,858
The only code-mandated colors are: ground must always be green or bare and those colors can never be used for anything else, neutral must always be identified gray or white and those colors can never be used for anything else, the high leg on a midpoint-grounded delta service must be identified orange. Everything else is optional.
But there's no need to take our word for it - you guys have code books. Tell him to show you where in the NEC it says you must use certain colors for 277 versus 120.
mpoulton is offline   Reply With Quote
Old 12-12-2011, 04:50 PM   #5
Exactly, poulton, it would have to be written down as a section if it were to be a code to abide by. I have yet to have a spec that required it as well.
Some tough inspector could fight that it falls under neat and "workman" like...
Holy Funk is offline   Reply With Quote
Old 12-12-2011, 05:07 PM   #6
dmxtothemax's Avatar
Rewards Points: 5,098
So does that mean that active or hot colors are not mandated ?
dmxtothemax is offline   Reply With Quote
Old 12-12-2011, 05:10 PM   #7
Rewards Points: 150
They are not mandated. We just try to keep it tradition. But it's not mandated
Old 12-12-2011, 05:16 PM   #8
Electrician
Rewards Points: 760
For people who are lurking and read this, white can also be a hot in a 240V circuit or a switch loop, so if you see a white don't assume it is a neutral. Yes your suppose to change the colour but that doesn't always happen.
darren is offline   Reply With Quote
The Following 3 Users Say Thank You to darren For This Useful Post:
ben's plumbing (12-12-2011), frenchelectrican (12-13-2011), SD515 (12-12-2011)
Old 12-12-2011, 06:05 PM   #9
Rewards Points: 150
But it's a violation if they don't reidentify the white as a hot. So technically we aren "Allowed to use the white as a hot
The Following User Says Thank You to Sunny B. For This Useful Post:
mpoulton (12-12-2011)
Old 12-12-2011, 07:13 PM   #10
biggles's Avatar
i work commercial HVAC in NYC always seen B-O-Y on 3 phase 240/480 into the disconnect and then to the units...never saw different
The Following User Says Thank You to biggles For This Useful Post:
Old 12-12-2011, 10:33 PM   #11
You can use white or gray conductors, but they must be re-identified as something other than white or gray. Any color can be re-identified as any other color, with the exception of green.
Old 12-13-2011, 05:21 AM   #12
Rewards Points: 150
You are correct, but when using # 8 or larger, we must use the right colors. We are not allowed to reidentfy wires that large
Old 12-13-2011, 06:53 AM   #13
Electrician
SD515's Avatar
Rewards Points: 504
Actually Sunny thatís not quite correct.
Ungrounded conductors of any size, in any wiring method, can be re-identified to indicate its use as an ungrounded conductors of a different color, except white or green.
For the grounds or neutralsin conduit: You can re-identify wires #4 and larger with white or green. #6 and smaller you must use the correct colors (white or green).
For cables: Whites of any size can be re-identified to indicate its use as an ungrounded conductors. Equipment grounding conductors can be made from a non-green wire only when the conditions of maintenance and supervision ensure that only qualified persons service the installation (usually only done in industrial), otherwise the cable must contain a green or bare conductor (which most cables do).
See 200.6, 200.7, 250.119, 310.12, 210.5, 215.12
Kyle
Old 12-13-2011, 01:08 PM   #14
Rewards Points: 58
Keep in mind, we as residential, commercial and industrial electricians rarely ever work on "High Voltage". I never have in 35 years.
Anything below 600 volts is considered low voltage. Then we go to medium voltage after 600 volts. I am not sure where high voltage starts. I assume its over 4160. Just FYI.
If you are in the trade you should come to the professional forum. You are welcomed and invited.
Old 12-13-2011, 02:09 PM   #15
MV covers either 1000-35,000V or 600-69,000V depending on whether you use the ANSI/IEEE standard or the NECA/NEMA standard. "High voltage" really only covers long-distance transmission voltages. Of course, in the electronics industry anything above line voltage is considered "high voltage". It's all a matter of context.
window condensation kmpittman Windows and Doors 4 11-29-2011 10:10 AM
Uneven floor and joists in new room Orangeclawhamme Building & Construction 35 11-16-2011 11:57 AM
sweating double pane windows etch Windows and Doors 6 10-31-2011 10:30 PM
tuck point a inside decaying chimney base ezj001 Building & Construction 2 09-04-2010 11:49 AM
Point of Entry Surge Suppression Question eltrigo Electrical 1 06-02-2005 07:14 PM
